Aluminium Heads
From Brisbane QLD
Hey just wondering, I got my A12 in my ute rebuilt after it #### itself and the bloke that did it put an aluminium head on it he had lying around. I just wanted to know, whats the advantage of an aluminium head? Just a weight decrease or is there a power advantage?
Posted on: 2006/3/21 7:29
Allan Jarvis
TOA57D Motorsport
Re: Aluminium Heads
From Vancouver BC Canada
the one he took off wasnt aluminum?
Posted on: 2006/3/21 7:34
If at first you don't succeed, lower your standards.
Keith (Mac-Datty)
Re: Aluminium Heads
Another advantage of aluminum heads is that they conduct heat better, and so can often use 1/2 point compression on the same fuel as compared to iron heads.
Posted on: 2006/3/21 7:48
Re: Aluminium Heads
From south australia
i think you will find that a12s
are all aluminium
Posted on: 2006/3/21 9:36
Re: Aluminium Heads
From sacramento california
the head on my 78 a14 is alluminum aswell.
Posted on: 2006/3/21 9:40
Re: Aluminium Heads
From Brisbane, Narangba
All nissan/datsun A-series have alloy heads.
J-series and pommy variants of this engine had cast iron heads.
Posted on: 2006/3/21 9:42
Re: Aluminium Heads
From south coast nsw
can i ask wat the consequences of not using a lead substitute on an aluminium head will be.? will the exhaust valves burn out or somthin?
Posted on: 2006/3/21 10:02
Re: Aluminium Heads
nearly all modern cars now have aluminium heads they all have hardened valve seats so there is no problem with unleaded fuel
Posted on: 2006/3/21 10:06
Re: Aluminium Heads
i run optimax and never squirt any in. this will b ok u reckon?
Posted on: 2006/3/21 10:19
Re: Aluminium Heads
it should be fine i
Posted on: 2006/3/21 10:23
