Ian Ogilvie proflex
From Christchurch New Zealand
hi does anyone know the spec's of Ian Ogilvie proflex eg pistion sizing, spring rates, droop spacers
Posted on: 2006/3/23 10:38
"If your not living on the edge your taking up too much space" Rod Millen
Re: Ian Ogilvie proflex
From Brisbane
The only person who would know what you are asking would be Murray Coote himself.
I know he is using a 150lb coil on the front and the piston size is probably about 36mm.
Not quite sure what you mean by droop spacer.
Posted on: 2006/3/23 11:32
