120y swaybar
From Adelaide, Australia
this sounds pretty stupid but, i had a lot of trouble trying to get a 120y swaybar off i ended up not even getting it. lol any others had this problem.
Posted on: 2002/11/21 3:30
Datsun
Re: 120y swaybar
From Melbourne, Australia
yeah undoing its easy but you pretty much need the wheels off to get it out
Posted on: 2002/11/21 3:46
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: 120y swaybar
From Sydney, Australia
I didn't have that many problems getting one off. I found the best condition one with the cleanest bolts/nuts. Only required a quick squirt of WD40 oil. You need to find one in good condition.
I had troubles fitting one on my CA18 1200, it hit on the CA sump. Apparently it might fit in upside down? If you get the chance, try and fit the swaybar in upside down and see if it fits. I don't think it will, because the bar is not flat across the section that bolts to the datsun subframe.
Cheers,
Chris.
Posted on: 2002/11/21 5:12
Re: 120y swaybar
From Auckland N.Z
i just pulled one off in the weekend. it wasnt to hard coz the car was on top of another car at a reckers and i could get at it while standing up. what was the problem? the nuts or the fact it goes through holes in the framework? the bolts were fine but i can see how it would b annoying if u couldnt see how to twist it to get it out.
Posted on: 2002/11/21 12:53
Re: 120y swaybar
couldnt twist it to get it out did you have to take anything else out. the car i tryed to remove it from had 1 wheel on
Posted on: 2002/11/21 13:16
Datsun
Re: 120y swaybar
From Canberra, Australia
Iv'e got an A15 in mine and it still hit the sump when I put it in...
Anyone else?
Posted on: 2002/11/21 13:20
Re: 120y swaybar
From Auckland, New Zealand
Quinn wrote:
i just pulled one off in the weekend. it wasnt to hard coz the car was on top of another car at a reckers .
HeY Quinn,
As you can see i'm from Auckland also... what wreckers did ya go to mate ???
Cheers
Posted on: 2002/11/21 20:01
#Datopower#
