Rotary in a 1000 Coupe
From Canberra. ACT
Hi all I hope you can help me. Can you fit a rotary in a 1000 ?? and if so what are the main problems I will face?? and what would be the best engine/ gearbox to use. Thanks all look forward to your replies on this
Posted on: 2006/4/22 5:41
Re: Rotary in a 1000 Coupe
Quite a regular
From Southside of Brisbane
yes they will fit, anything will fit with enoguh work. In QLD you can only put in a 10A engine which has to be asprated. I was thinking of gong down that track but good luck finding a 10A motor, If you are lucky your rules might be more flexible but I doubt it. there is a 1000 coupe (2 dour sedan) that is in perth that has a 13b supercharged rotary in it. It does 8.5 sec 1/4 mile from memory. If you do a search on the site I think there are some picture and information about it. It is bright yellow, was also featured in one of the car magazines a year or so ago
Posted on: 2006/4/22 5:46
Lead
From Canberra. ACT
thanks mate yeah a 10a ? reckon it will rain new 100 coupes before I found one. Do you know what address I would find anything on the yellow one you mentioned?? and would you have any idea about the stearingbox and the exhaust I have been told they would be a clearance problem there as well?? Anyway as usual someone here is willing to help people out so thanks heaps
Posted on: 2006/4/22 8:21
From Perth
read this thread
and this one
And search for brake and suspension threads too
Posted on: 2006/4/22 9:45
Someone mentioned to me that they have a friend who recently bought a R100 with a 10A in it. And I believe he was going to swap it for a 12A.
He'll probably read this thread soon too
Posted on: 2006/4/22 12:26
Datsun 1000 ute - Building (slowly)
Datsun 1600 13B turbo - coming soon
From Flinders View, QLD
I am not LEARNED on the rotor side of the fence, what is so rare bout the 10A and are they any good.
Posted on: 2006/4/22 13:44
10A were the first factory Mazda rotary's. And no, they aren't really much good, hence the fact they are so rare
Posted on: 2006/4/22 13:48
From Springwood NSW, Formerly Tas.
you mean this one?
Posted on: 2006/4/22 23:58
1978 120y Coupe.
Quite a regular
Yes, that is the car I was talking about.
As for the 10A it is rare because you are unable to get big horsepower, mainly due to the main seals you are required to use, I had a friend who had a monster port 10a and he would have to put seals in it about every 15000 km's as they would not hold up. Speak to any rotary specialist and they will tell you to stay away unless you are really desperate, thus the reason am going down the nissan motor path. I believe you will most likely get bigger numbers out of a turbo nissan motor than a apirated 10A rotary anyway.
Posted on: 2006/4/23 0:30
Lead
Well guys I have the exact project now but stumbled with the exhaust part of things.
The problem is the steering box and I dont know how Huntingdale autos have managed here. Datoman1000 has done enough favours to get the photos he has already for me so I wont ask again. However I feel that this car is only getting 8.5 seconds intead of mid 7s because of the restrictive exhaust. Ive tried trial fitting for the best positiong and the exhaust has to be very tight and curved quickly to fit. Unlike any other american cars that have the steering box on the side. One way I found that improvements can be made for a better exhaust is by tilting it 20 degrees. This will need custom bellhousing, front mount and custom sump (well sump will be custom regardless). It wont suffer from any oiling problems when titled and factory twin honda vtr 48mm mikuni carbs running at 60 degrees will fuel it nicely and better than a 48mm weber when jetted properly.
Ill take pics as soon as Ive worked out the bellhousing issues otherwise Im going to plan "twenty" which another totally different engine which I have sitting there impatiently.
Posted on: 2006/4/23 2:24
