« 1 (2) 3 »
Re: Best way to lower the back?
From Brisbane, Australia
I wouldn't flip the main leaf - it will be WAY too low.
If you want a cheap and very effective leaf pack, I'll check exactly what I did with my old coupe when i get home tonight and post details and a pic.
Posted on: 2006/5/2 7:50
Dodgeman wrote:
& if the rear springs are properly reset, the ride will be a little stiffer as well.
Do you care to explain how you come to this nonsense?
A leafspring gets its strength from its thickness plus its arch.
If you reset them flatter ( since you wish to lower) How does it get stiffer? It has now lost much of its arch strength and is relying on its thickness.
Is there some magical way that you know how to flatten a leaf and make it stronger at the same time?
The only real way to strengthen (make stiffer) a reset lower leaf spring pack, is to either add more leaves or replace leaves with thicker leaves.
Posted on: 2006/5/2 12:14
From Vic Bendigo
hey phunk i was wondering wether the person in ur pic is that u
Posted on: 2006/5/2 12:20
Yeah thats me at work. I am the only guy there with the latest mac. Can you handle that big guy?
Posted on: 2006/5/2 12:28
From Vic Bendigo
no i was just wondering didnt mean to b rude
Posted on: 2006/5/2 12:34
From bend oregon
I would say use thethe blocks because you can always undo it if you need to. Blocks will still maintain a decent ride. And yes keep the wheels
Posted on: 2006/5/2 14:21
From Vancouver WA. U.S.A.
alright thanks for all the advice and sorry for posting this in the classifieds, I will try the blocks first since I already have them
Posted on: 2006/5/3 7:14
BE sure to check out my coupe build thread and feel free to leave comments good or bad.
[url=http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=36107&fo
L18_b110, I would still like the info on the pack you use to run
Posted on: 2006/5/4 7:48
Well blocks are a time honored way of lowering the back.
For the front, you'd need to cut 1/2 a coil off. Or just use those hokey "spring clamps" ...
Posted on: 2006/5/5 4:54
I had a 66 cutlass that had those hokey spring clamps on all 4 corners
Posted on: 2006/5/5 7:03
« 1 (2) 3 »
