From Brisbane, Australia
no, the L18 conversion is not as simple in the 1200. trust me! Alot of fabrication work required to crossmember, engine mounts, etc.
If it's just a car to learn in, you probably want to keep it cheap and simple, but with enough power to learn about car control.
So if it was me, I'd rebuild the A12, throw in a 30/70ish regrind cam, and a downdraught Weber, mill .030 or .040" off the head to bump the compression up a bit. Then a cheap 1.75 sports exhaust, maybe a 2nd hand set of extracters if you can find some. I wouldn't bother porting the head - with such a mild engine, there won't be any real benefit. Same goes for getting an A14 oval port head - if anything, you'd probably loose a bit of power on this engine, because it will reduce the velocity of the inlet charge which gives better cylinder fill. Besides, it's money you don't need to spend.
you could drop in an A14, but that will cost as much as the parts to rebuild the A12. And you'd probably want to rebuild that before throwing it in anyway, and this is where it all begins to get out of control... But I guess if you are planning on an A14 for the coupe you are building up, then it's not money wasted. But in NZ, you can throw in just about any engine you want in a rally car hey?
Posted on: 2002/12/2 1:35
