datsun motor
From Darwin NT
i need help with finding out what my motor is in my 1000 the mounts have been moved back maybe 2 inches? help would be good
Posted on: 2006/5/21 8:40
Re: datsun motor
Have a look at the engine number pad. The first three Characters will be either A12, A14, or A15. If the mounts aren't in the original place, then it will have the distributor under No. 3 plug & the engine number will be just to the rear of the engine from there.
This will be your engine model code & basicly it means
A= A series Datsun engine
12= 1200cc
14= 1400cc
15= 1500cc
It's all too easy once you know.
Posted on: 2006/5/21 9:01
Love your Datsun.
Treat it well.
Re: datsun motor
From Darwin NT
thats the only problem i cant find a12 a14 or a15
Posted on: 2006/5/21 9:16
Re: datsun motor
From UK
I've had an A series before with a blank number pad on the block. You can at least tell an A12 from a 14/15 by the manifold bolt pattern. as I think even the later A12's still retained the early style bolt pattern. Anyone like to confirm that?
-Ed
Posted on: 2006/5/21 12:10
Re: datsun motor
OK, I am guessing that it has the distributor near No. 3 plug, so we can rule out A10's & 1200 engines.
Next, look at the distance of the head from the bellhousing. This will at least rule in,.. or out, the A12 engine.
If the distance is short, as in this photo, then you most likely have an A12 engine from a B210/ 120Y or a B310/ Sunny sedan.
If the distance is large, like in this shabby flick, it will most likely be an A14 or A15 engine.
Posted on: 2006/5/21 13:30
Love your Datsun.
Treat it well.
Re: datsun motor
From Darwin NT
thanks for that dodgeman should help and would you be able get any measurements from both engines?
Posted on: 2006/5/22 10:59
