squeaky/sick sound in steering column
From Bunbury Western Australia
My steering column has just started making a weird squeaking or groaning sound when I turn the wheel. Is there a way I can lubricate it or replace the bearings? I noticed a removable plastic tab on top of the column is this a lubrication point? also I think my oddomoeter is also making a slight squeak each revolution and it's getting to me bad
Posted on: 2006/6/22 8:33
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
Re: squeaky/sick sound in steering column
From Townsville, Qld
I wouldn't mind knowing this also since my 120y colum squeaks past it's center posistion
Posted on: 2006/6/22 10:07
From Sydney, Australia
The horn connection has a brass swiper that wears out if not lubed up every couple of years.
The top bearing also wears out. If it has, other scraping noises start up.
Get a phillips head screw driver, and track it down, anyone would think you were allergic to pulling your datto apart...that's a very unusual characteristic of a Datto owner.
Posted on: 2006/6/22 10:55
no not allergic to pulling it apart I just like to know what to look for first since I have limited time to do work on the car.
But thanks for the tip
Posted on: 2006/6/22 11:40
