Import Seats For 1200 Coupe?
From Darwin
I have to replace the seats in the datto 1200 coupe I bought. I am thinking maybe mr2 seats or mx-5 seats - Has any one tried to fit these sorts of seats? Or does anyone have a succes story with any other seats?
Posted on: 2006/7/5 11:54
everyone is s
Re: Import Seats For 1200 Coupe?
From Brisbane
mine are mr2 seats, i removed the spot welded brackets and reweld the seats onto some angleline that gets bolted to the original mounts, you only have to grind a bit of metal under the back of the seat for them to fit.
Posted on: 2006/7/5 12:02
From Flinders View, QLD
I got gemini buckets in my 1200 ute. Bit of welding and drill 2 holes and she fits like a glove.
Posted on: 2006/7/5 13:23
From Albuquerque, New Mexico USA
I have Mitsubishi Eclipse seats in my 1200 Coupe, the last owner fabricated extented brakets to mount them - I'll post pictures after I get some more batteries and clean up my ride
Posted on: 2006/7/5 13:53
www.DATPART.COM
Word to the Spookies...
From Huntington Beach, California
I have either MX-5 or MX-6 seats in my coupe. (I think they were from a '92)
I used the Mazda seat rails and made some rear brackets to mount them. They are very comfy, and one of the best upgrades to my 1200 I have done so far.
Posted on: 2006/7/5 23:44
I've got FTO in mine. They are comfy, but unless you've got a welder and alot of time I'd go aftermarket.
Or try and find some with seat rails which arent uneaven! (usually the tunnel side of the seat is higher)
Posted on: 2006/7/6 8:21
From Okinawa, Japan
I put R32 GT-R seats in my ute. Mostly because of how thin they are which gives every bit of available cabin space in a ute, and they were free. Had to fab brackets using a combination of the original brackets and GT-R seat adjusters. Also, since they're uneven I had to make some spacers to make the fabrication easier on the passenger side. Took most of an afternoon, but well worth it.
Posted on: 2006/7/6 10:21
From Bunbury Western Australia
I used Tenzo racing seats in my sedan and used the same bolts and seat rails to fit the seats! tokk me about 1 hour to remove the old seats and fit the new seats no drilling or anything required....as if they were made for 1200's!
Posted on: 2006/7/6 11:49
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
