Re: Pair 40mm dcoe webers
From brisbane, qld
Just got off the phone. The distributor 4 Redline performance parts should be able to help you out. As previously mentioned, $500 plus then you have to buy emulsion tubes and jets to suit you application. (as long as you know which ones you need). So you are looking at around $600-$700 EACH!! Plus shipping. Get on to redline, Im sure they will sort you out, no worries.
Posted on: 2006/7/25 3:52
Subject Poster Date
     Pair 40mm dcoe webers carjunkie 2006/7/16 14:03
       Re: Pair 40mm dcoe webers nismo 2006/7/17 11:24
         Re: Pair 40mm dcoe webers carjunkie 2006/7/19 2:12
           Re: Pair 40mm dcoe webers nismo 2006/7/21 11:37
             Re: Pair 40mm dcoe webers carjunkie 2006/7/21 12:28
               Re: Pair 40mm dcoe webers LittleFireyOne 2006/7/22 2:34
                 Re: Pair 40mm dcoe webers blofly 2006/7/25 3:04
                 Re: Pair 40mm dcoe webers carjunkie 2006/7/25 3:39
                   Re: Pair 40mm dcoe webers carjunkie 2006/7/25 3:52
                     Re: Pair 40mm dcoe webers short-coupe 2006/7/25 9:41
       Re: Pair 40mm dcoe webers carjunkie 2006/7/19 2:11
