Poly bushings in US
Quite a regular
From Portland OR. USA
Hey everybody,
It seems that Nolathane is the only company that makes poly bushing kits for the 120y. I'm having trouble finding a distributer here in the US, and can't find anyone to order from in AU.
I tried Noltech(sp) but it seems that they only make the rear spring bushings. Help me get rid of 30 year old rubber.
Thanks,
Ryan
Posted on: 2006/8/4 0:40
Re: Poly bushings in US
This is a link to the Nolathane site which gives a listing of all that they offer for the model.
You may want to contact them & ask about a US distributor. I'm sure that they can help out one way or another.
Beware of the rear spring eye bush, No. 47156 as these are 22mm in diameter & I believe that you will need one that is 23mm in diameter. That's what I found with my 1200 coupe anyway.
To get around it, I bought another set of bushes for the chassis half of the shackles [47157] as these are the right size, only longer, so shortening is all that should be required.
I will be fitting mine today.
You could try Noltec for these spring bushes, but measure your old ones first, then ask them to tell you what size theirs are.
Posted on: 2006/8/4 1:00
Love your Datsun.
Treat it well.
Quite a regular
Thanks for the info. I've tried to contact Nolathane before, but the message was sent back as a bad mail address. I'm trying one more time through their international link. Wish me luck.
Posted on: 2006/8/4 1:34
From Burbank, CA
you'll probably have to have them shipped from australia.
contact datman55 - he helped me get my full set of noltec urethane bushings. They are very nice, it's a bit of $$ but well worth it.
here's a list of the bushings needed and quantities and part #'s ( if you have a 4 link sunny - most are the same still )
parts list 1.0 MB pdf
Posted on: 2006/8/4 20:03
|||\ 81 KPB310 /|||
From Perth
PM Sent
Mark.
Posted on: 2006/8/6 0:36
