Howdy Y`all, I have just finished phase one of "project 4x" (four x std power) in a standard `67 1000 2dr.
I pulled the motor from my little redwagon ( a15, t03 turbo ((same as vl)), 1.75 stromerg carb, water/meth, 30 psi ??kw, 17psi 105kw) and put a shiney new dellow 5 speed behind it, unknown prop shaft, and a BW 120y back end in.
I set the boost at 10 psi for the initial shake down (no water/meth, and i didnt want to break my new 5 speed) no probs.
This weekend I fitted water/meth, wound the boost up to 17 psi and adjusted the clutch the only prob was that the little 155/80/R12 chesse cutters tend to let go above 4000 rpm.
I still have to put in the welded diff from the wagon and fuel pump (holley blue) then wind the boost back up to 25-30 psi.
Do you rekon the celca box will handle it. I had a ford cortina 4 speed in the wagon and it never had any probs?
