« 1 (2)
Re: how much power out of an a14?
From Gold Coast
think it's a 56a, does that sound right? thanx for the info. Might do that next..
Posted on: 2006/8/5 10:22
Not too shy to talk
The A14 with a T25 and a good efi setup will be plenty of fun.
The one I've got is pretty amusing
A set of ACL pulsar turbo pistons in the A14 will drop the comp enough, and they are tougher.
A mild cam will help airflow to get the turbo onto boost quicker and grant you more top end. You need less boost to make the same power as a stock cam.
If it's put together right I'd say upto 200rwhp isn't out of the ball park. The porblem will be everything behind the motor going bang.
Posted on: 2006/8/8 13:41
From Gold Coast
i have a bluebird diff in atm will that hold?, what sort of gear box would i have to go with? i just put the 56a 5 speed box in lol.
Posted on: 2006/8/9 7:25
From Gold Coast, Australia
the H165 is seriously tough hey, were running it with my brohters SRturbo ute and its holding up alright and were thrashing the diff eg spinning through 3rd gear, it is starting to moan though hahaha. im keeping the H165 in my NA sr. also the weak point in the diff is the axles the centres tend to hold up. And the torque of the turbo SR is alot more than you would expect from the A series so you shoudnt have a problem.
Posted on: 2006/8/9 7:41
From Canberra
that would be insane, my fj20 only makes 160rwhp, and weighs about 100kg more
Posted on: 2006/8/9 7:50
From Sydney
I would think the diff will hold up, but a 56A five speed behind a boosted A14 probably will not.
Posted on: 2006/8/9 8:05
Not too shy to talk
200 at the tyres would be a full house mean mother of an A14, perhaps in the upper limits of the power capabillties.
I just remapped the ecu on mine the other day with a bit more of a road tune, more aggressive timing map. althoug kept at about 10-11 psi. As a result of the power increase I have today just destroyed a gearbox( 3rd gear has no teeth left) It was in gear accelleration, with very gentle changes. 56A box. I fortunately had a spare, although that little experience tells me I need something alot tougher.
got to love a gearbox you can hold in one hand though.
Posted on: 2006/8/9 12:28
Not too shy to talk
I think part of the reason the 165 ute diffs hold up is because the drive wheel usually spins so much. I'd say an LSD center and sticky tyres might kill it pretty quick with turbo power.
Posted on: 2006/8/9 12:30
yeah good point therye tough enough to the point you loose traction but not for slicks and LSD's.
Posted on: 2006/8/9 12:33
From Gold Coast
how much will that cost roughly?
also the diff in it atm i was told is a "rare bluebird.....3.7:1 diff"
Posted on: 2006/8/10 9:17
« 1 (2)
