tailshaft lengths ??
yeah, yeah, i know .... use the serch bar !!
i have and this is what i've found :
B110
Same for all 1971-1973 models (including ute)
End-to-end length nearly same as B310 (though diff flange differs)
1189 mm (u-joint to u-joint)
68.9 mm Tube diameter. 1.6 mm thick
20 mm Sleeve yoke (slip yoke) diameter. 1.6 mm thick. 3.150 mm pitch splines
B310
Length
End-to-end length nearly same as B110 (though diff flange differs)
49 inches from rear flange face to beginning of yoke slip surface
1045 mm manual (u-joint to u-joint)
1177 mm auto (u-joint to u-joint)
what i want to make sure of is that ALL MANUAL 1200 MODEL TAILSHAFTS ARE THE SAME LENGTH (1045mm u-joint to u-joint) regardless of the diff being an H145 or H165 ?? the only difference is the diff flange ??
is this correct ?
or if someone has a ute tailshaft lying around could they measure it for me from face of diff flange to the centre point of the gearbox uni ??
all help will be much appreciated
cheers in advance
Posted on: 2006/8/14 9:00
Re: tailshaft lengths ??
From Brisbane, Narangba
The ute tailshaft is slightly shorter to allow the longer snout on the diff.
Posted on: 2006/8/14 9:06
From Brisbane Australia
ive got 3 manual tailshafts if that helps
ade
Posted on: 2006/8/14 9:16
any idea how long slightly is ??
it could help ?? if one of them has an H165 flange on it and you could give me a measurment
Posted on: 2006/8/14 9:53
From Bendigo, Victoria, Australia.
only a few mm.
i think if you get a bit of 3mm sheet and cut it out to the right shape its as good as snugg.
Posted on: 2006/8/14 10:43
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
Did a quick run down to the shed.
133.5cm for h145
129.5cm for h165
Thats from flange to yoke.
Posted on: 2006/8/14 12:18
cool .... thats what i'm after
cheers freak
now i can get the spare sedan tail shaft cut and a 165 flange all fitted and balanced then the lsd can go in
Posted on: 2006/8/14 12:28
No worries mate. Cant wait to hear how the LSD goes.
Posted on: 2006/8/14 12:31
From Melbourne AUS
if your getting your sedan tailshaft modified for the h165 and you want to be sure...
fit the h165 diff to the car.. then measure from the end of the gearbox to the diff flange... then allow 25mm for suspension travel and theres your total length!
Posted on: 2006/8/14 12:36
1973 B110 A12
thanks ange, i was hoping to have all the bits sitting there to do at once as i've got a spare sedan tailshaft sitting in the garage ..... at the moment it looks like i'll be doing diff, tailshaft and coilovers all in one hit if i can stretch my wallet that far ......
Posted on: 2006/8/14 12:43
