« 1 2 3 4 (5) 6 7 8 »
Re: Gearbox fill bolt - stuck!
From SE Melbourne
Maybe the heat just breaks up the rust - my contention was that if Aluminum expands quicker than steel - wouldn't the hole get smaller around that bolt?
So it's proabably more about the threads moving, the rust breaking up - that sort of stuff.
Too much physics in my head I guess.
Your right about me not having much to lose - or I can go down the breather pipe/shifter hole filling option.
Posted on: 2006/8/14 12:51
Mildman, Datsunless
From Taupo New Zealand
I don't know if i can explain it very well but the reason that the hole will grow larger rather than smaller is that when you heat it up, the metal expands. If you think about the inside of the hole, if the diameter gets smaller, you are actually shrinking the metal.
When heated the molecules will have more kinetic energy and need more room to resonate. or whatever Al alloy molecules like to do with their energy. If you think of the molecules that make up the filler plug hole as a bunch of people all crowded together holding hands in a circle, if they all move in towards the centre of the circle they get more squashed and uncomfortable, which would happen if you cooled the gearbox. If the people in the circle start dancing around and waving their arms and doing star jumps, they will have to increase the size of their circle, which is pretty much what happens when you heat the gearbox housing around the filler plug.
Sorry for a pretty crappy analogy and if you don't get my drift I do understand. Just TRUST me and others who know that it works!
Posted on: 2006/8/15 9:55
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From SE Melbourne
I do see what you mean - there is a bunch of stress around that diameter - heating it up relaxes the stress a little, so the diameter should grow once it is allowed to relax a bit.
I'll have another crack at that bolt this weekend...thanks for the extra explanation - helps my brain grow bigger...plenty of room in there for more!
Posted on: 2006/8/15 10:07
Mildman, Datsunless
From Canberra
Straight to the poolroom wall with that little beauty. Well done!
Theres not to much "dancing around" going on but you have a handle on what happens with heat. The expanding of the alloy happens along its structure (like slivers or fault lines in rock) depending on the grade and the manufacturing processes used.
I say it again - the co efficient of expension of alloy is greater then that of steel - therefore the alloy will be bigger than the steel for any given temp(up to a point).
The structures of most metals can be changed with the use of both heat and cold. Keep in mind that you will only be using low heat which will grow the alloy and it will return to its original "room temp" state once it cools.
Posted on: 2006/8/15 11:21
this might sound stupid but i've had similar issues and one of these 2 options may work ??
try to tighten the plug .... it may break the seal and allow you to unscrew it ...
or ..
if you can get a hammer in there with a bit of swing, hit the plug 'into' the gear box .... can have the same effect as tightening it by shocking the seal.
might be worth a try but just thinking of it, the plugs are tapered aren't they ?? give it a go anyway ... doesn't sound like you've got anything to loose
Posted on: 2006/8/15 11:40
From Brisbane, Narangba
Heat from an oxy does work. Its all about breaking the seal like boof said, not wether its going to expand or not casue thats the whole idea. It will shrink back anyhow.
Posted on: 2006/8/15 12:43
From SE Melbourne
A mate of mine (dealership mechanic) was mentioning that to me this week - if it doesn't undo he then tries to tighten it more, then untighten again.
Looks like I've got a few strategies to try, if only I'd thought of them earlier...ahh the situation is still salvagable!
Posted on: 2006/8/15 12:51
Mildman, Datsunless
From SE Melbourne
Had another crack at this bolt today....here's how I went.
Went down the heat up and crack bolt path - also liberal sparys of penetrant, tighten then loosen...sadly nothing worked - temporarily I'll admit defeat as my get Blue Coupe running deadline approaches.
So can you REALLY fill transmission fluid through where the gearstick is usually mounted - I've had a look and there doesn't seem to be much room for the oil to get into the extension housing...
Posted on: 2006/8/20 12:37
Mildman, Datsunless
From Melbourne AUS
dumb question...
but if....
This car is only going to get driven once or twice - then up to the country for a complete strip and paint job.
why are you changing the gear oil now
Posted on: 2006/8/20 12:48
1973 B110 A12
From SE Melbourne
Well spotted there Ange...well the gearbox is empty of trans fluid at the mo'
But it's about not letting the bolt win too.
Posted on: 2006/8/20 13:01
Mildman, Datsunless
