Browsing this Thread:
1 Anonymous Users
Re: Car wont start after head gasket replacement. |
From perth
Hey all after a little closer look at the engine lead set up i know from experience (i think) in the 1200 workshop manual it tells you to put the leads on the way you have on the dizzy...BUT that didnt work for me...were u got ignition lead 4 on the dizzy put number 1 lead and work around from there again...if you didnt take the leads of the dizzy cap you may have the dizzy cap on the wrong way...hope it helps...
Posted on: 2006/8/22 15:07
From Adelaide, Australia
Prospec, all that means is the dizzy is out 180
Posted on: 2006/8/22 15:09
cheap + fast = disaster fast + reliable = expensive cheap + reliable = stock IPRA Build
From Adelaide, South Australia
Pump lots of fuel in a the valves should be set to .25mm.
I did my head this week and got a new head with rockers on it.Used it how it was and the dam thing wasnt oiling the rockers had to use the one from the old head.
How long has it been off the road ?
Posted on: 2006/8/22 15:35
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
From bend oregon
Correct me if Im wrong but the plug wires are out by one evrything needs to be moved by one counter clock wise shouldnt #1 be above the vacuum advance?
Posted on: 2006/8/23 2:41
From Bunbury Western Australia
I would try a compression test if the valve clearance adjustments don't work, did you end up swapping heads or just try reusing the old corroded head? to be sure you have the distributor wiring done right I have taken the distributor cap off and the rocker cover off and proceeded to turn the engine over checking the rotation of the distributor and counting the strokes of the number 1 cylinder by watching the valves open then close to work out when the number 1 cylinder should fire. Hope that helps
Posted on: 2006/8/23 3:50
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
I'm about to go out and adjust those valve clearances. Hopefully it should work.
I'm very sure that I've got the leads in the right order (as I did number them as I took them off) and the dizzy cap is definatly on the right way. It only fits one way.
I also got my head fixed up as it would've been cheaper then swapping all of my gear on to the head that I got courtesy of a mate of Tyrie's (cheers mate!) It turned out that the head I got off your mate was exactly the same as mine!
I had mine cleaned, alloy welded and decked ready to go back on.
Posted on: 2006/8/23 8:19
Well, you guys were exactly right. I adjusted the valve clearances and poof! she fired up...
But...
After about 5 minutes of idleing I noticed there was still steam coming out of the exhaust and after a further 5 minutes at the back of the head water was starting the creep out...
Not happy!
I'll get the head back off and inspect it again and try it once more... but if it doesn't work I might just consider a swap an A15.
Posted on: 2006/8/23 8:24
From Canberra
that sucks dude, I can still come around saturday if you need a hand
Posted on: 2006/8/23 9:40
Not too shy to talk
From wyong
hey do u know the firing order for a j15??
Posted on: 2006/8/23 11:15
From Vancouver BC Canada
Looks like you need to get your head shaved for trueness. Glad it was what I suspected, but bad about the failed gasket...
Posted on: 2006/8/23 23:58
Quote: If at first you don't succeed, lower your standards. Keith (Mac-Datty)
