(1) 2 3 4 »
COIL-OVER KITS
From Adelaide
I am producing Weld on coil-over kits. They consist of Zinked steel threaded tubes with 51mm ID to suit most Datsun/Nissan struts. Billet Ally locking nuts and top hat, and locking spanners. They are to suit 65mm compertion springs. Very simple to fit, but must be welded on to struts. $195 oer set.
Scott
Posted on: 2006/9/14 13:40
Re: COIL-OVER KITS
spewing big time if you'd come up with them about 6weeks ago i could've been your first sale
good luck with the sales
Posted on: 2006/9/14 14:15
Re: COIL-OVER KITS
From SE Melbourne
I'm interested.....I'm a little behind boof in development.
Posted on: 2006/9/15 0:22
Mildman, Datsunless
Re: COIL-OVER KITS
From Adelaide
Will these fit R31 struts?
Posted on: 2006/9/15 4:07
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
Re: COIL-OVER KITS
Will they fit Stanza struts? If so I'll be interested.
Posted on: 2006/9/15 4:39
Re: COIL-OVER KITS
From Adelaide
Boofhead, I would of loved to sell you a set, anyway at least you have some now.
Posted on: 2006/9/15 13:08
Re: COIL-OVER KITS
From Adelaide
Rock1200 and Daveman, they will fit both struts or any strut with a 51mm shaft. I have them on my R31 struts, just weld on the threaded sleves and your done.
Scott
Posted on: 2006/9/15 13:12
Re: COIL-OVER KITS
From Sydney, Australia
Do they suit your strut camber plates?
I still haven't got around to using your nice camber plates yet. I need to make up a conical bush, and remake the nuts to reach the full depth of the pillow bearing. If I stick with standard diameter springs the adjustable tops are limited anyway.
I'm quite interested.
Posted on: 2006/9/15 23:17
Re: COIL-OVER KITS
From Newcastle
Yeh ill get a set aslong as were sure they fit the stanza struts. . .
Posted on: 2006/9/16 0:20
Re: COIL-OVER KITS
From Adelaide
Dattodude, i do have a complete coilover set up to suit my cambertops, and also have a selection of strut insert nuts to suit most of them.
Scott
Posted on: 2006/9/17 13:58
(1) 2 3 4 »
