« 1 2 3 (4)
Re: Rad support panel - effect body stiffness?
From Geelong, Vic
yeah i was about to say, most toyotas were designed like that
whitesedan, my brother likes your corolla hes seen it on toymods
are you in the same shed as scott? with the 250crossflow and rb30 ke20s?
yes i know this is off track
oh ive cut my radiator support out and made it bolt in
Posted on: 2006/10/12 12:24
From Adelaide, Australia
Yep sure am, they are nutters, theres matt with a ke30 4age as well in there. Scotts a mechanic and matts a painter, then my best mates a panel beater, got it all, get it all for free!
Posted on: 2006/10/12 12:27
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Geelong, Vic
my brother is hurricane on toymods, has the turbo celica, 3tc ke20 and 2 ke10s
hes mates with scott
Posted on: 2006/10/12 12:30
Ahh its a small world! Are you going to the datnats next year, would be good to meet all the guys from here, hopefully i can afford to get my car interstate and out on the track!
Posted on: 2006/10/12 12:42
IPRA Build
current 3 or 5 series bmws actually use a glue from factory for the radiator supports repairiers have told me, they use pot rivets to put them back in after accidents as its stronger than the factor glue method....
they would probably have more strucual riggidity than a 1200 though
Posted on: 2006/10/12 13:03
From Perth Western Australia
I cut mine out heaps... cut it with a hacksaw to keep the slots as small as possible. It doesn't seem to have moved yet. I will re-measure and double check when i weld back in. For the mean time though, with all the trial fits etc it sure is a lot easier to slide it in and out this way.
It would be easy if you had a hoist... just make up a frame or something to sit the motor on, lift the car up, wheel the motor under, and drop the car on top.
Think i'm gonna get me a hoist....
Posted on: 2006/10/12 14:23
« 1 2 3 (4)
