« 1 (2) 3 »
Re: What fuel does evry1 run in thier dattos
From Brisbane, Queensland
BP utilmate mixed with octane booster.
Posted on: 2006/10/13 7:44
From Rocky Queensland
can you run plain unleaded in a 77datto ute? standard a12
Posted on: 2006/10/13 7:46
From Adelaide, SA
So nobody adds lead replacement?
Posted on: 2006/10/13 7:53
From Brisbane
I never run anything below 96oc but with new Lseries will need to be 98oc only nuthing less!
Posted on: 2006/10/13 8:06
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From brisbane
i think somebody is playing a trick on you converted,what makes you think there is detergent in optimax?mabye the spark plugs "carbonise" due to the oil your engine is consuming.
for the record bp ultimate is the best,cleanest and most consistent 98 octane on the market.
more people use it straight up or with additive in street racing circles than any other.
standard unleaded should be avoided at all costs.it barely meets australian standards for octane and quality.it causes damage to fuel injectors and clogs them up.
if you want to see what is in unleaded,get one litre in a clear container and leave it open in the sun untill it has evaporated,and see what is left in the container.
Posted on: 2006/10/13 10:08
From bathurst nsw
i use bp ultimate + nulon octane booster as the little A15 has a compression of 220psi so i need to run it to stop the ping at full revs
Posted on: 2006/10/13 12:53
From Gold Coast
whatever 98 , 20 bucks last a while (monthly driver)
Posted on: 2006/10/13 14:32
z18-microtech-frontmount-t3/t4
-external gate-screamer pipe-
From Burbank, CA
Propane ;) Cheap, clean, 110 octane
Posted on: 2006/10/13 18:52
|||\ 81 KPB310 /|||
vortex 98 only cuase its on the way home from work, other wise mobil synergy 8000 or bp ultimate (same refinary in melbourne anyway)..... i like the mobil but vortex is a close second.
I stay away from shell, they changed the 98 octane formula again and the 100ron is crap for carbys as it has ethanol (not recomended for carby cars)
Posted on: 2006/10/14 6:18
In my stock 1200 coupe I run whatever comes out of the unleaded pump at whatever service station is nearby. I give it a shot of lead replacement juice when I fill it as the valve seats in stock 1200's are quoted as being made of 'Cast Iron' [Gregories No. 87, page 7] & I choose not to risk it.
My owners manual says it needs 90 octane or better, & it runs as sweet as you could wish for when tuned to factory specs.
Mmmmmm, low cost fuel, Datsun saves yet again.
Posted on: 2006/10/14 7:38
Love your Datsun.
Treat it well.
« 1 (2) 3 »
