(1) 2 3 4 ... 6 »
dohc a series
From Darwin NT
ok i know this has been discussed before but i have read in the tech section about a mazda b6 head bolting onto an a series block with all the water galleries lining up but the oil pasages dont and there are about 5 different heads that are on the b6 series of motors some came with turbos some didnt some are sohc some are dohc so which one is best?
Posted on: 2006/10/23 10:53
current project 4x4 patrol...
Re: dohc a series
From sydney
I dont know if this is the answer you are looking for but here goes,
None of them are best, I doubt if you ever got the whole thing to work properly it would offer any advantage over a well done A series head.
The Jeff Taylor A15 in John Taylors car used to flog the multi valve 4age powered cars on the track.
As a wealthy Australian used to say "When your on a good thing ,stick to it."
Posted on: 2006/10/23 11:05
Re: dohc a series
From Perth WA
I thought it was the GA16 head off a Nissan N16 or so Pulsar??? And a Vauxhaul???
Posted on: 2006/10/23 11:06
Chris...
Re: dohc a series
From Darwin NT
yes there is kind of an advantage the fuel injection is alot easier and cheaper to come by the a series fuel injection
Posted on: 2006/10/23 11:12
Re: dohc a series
Not too shy to talk
From murwillumbah nsw
i would have to agree i mean how much money do you intend to throw at this thing you could turbo an a14 get better power and do it for a lot less money!
Posted on: 2006/10/23 11:20
Re: dohc a series
From Darwin NT
well the water galleries all line up but the passages dont so plug em up then run an external oil feed to the head have the cams driven by a belt externally
Posted on: 2006/10/23 11:27
Re: dohc a series
From Townsville, Qld
Yeah it would be nice if we had Doch technology. I have a friend with a Fiat 124 coupe and he's slotted in an 1800 twin cam engine of the same make and it's (and I quote another friend) "Porn"
Posted on: 2006/10/23 11:45
Re: dohc a series
From Darwin NT
heres a pic of the turbo version....
Posted on: 2006/10/23 11:49
Re: dohc a series
From Adelaide, Australia
How would you drive the dizzy and oil pump, they are run off the internal cam.
Posted on: 2006/10/23 11:53
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: dohc a series
From Darwin NT
just keep the cam still there connected up driving the dizzy and oil pump
Posted on: 2006/10/23 11:56
(1) 2 3 4 ... 6 »
