« 1 (2) 3 4 »
Re: twin weber dilemmas, not running right
From Sydney, Australia
Sounds like your weber -> manifold gaskets are leaking. Also could be leaking in through the butterfly axles.
Either way..it's running lean at idle.
air/fuel ratio is harder to balance at idle, and more prone to be affected by leaks.
The BOV noise was an intake backfire caused by lean mixture.
As you say it's started doing this lately, either you have an air leak or the idle jets are getting blocked.
Posted on: 2006/10/30 10:43
From Adelaide, Australia
Do a plug test, is it white or black.
Posted on: 2006/10/30 10:46
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From campbelltown (sydney) australia
i thiunk we found the problem, had a leaking fitting at the manifold
Posted on: 2006/10/30 11:08
* caution, sunglasses must be worn to view my ca18det *
Excellent!!
Posted on: 2006/10/30 11:23
IPRA Build
From Wamboin near ACT(canberra)
yep its all fixed, was a leak on the manifold, so relived now
Posted on: 2006/10/31 10:38
ok, things arent so good anymore, well the utes running fine. BUT, now on the fuel pressure guages its running at 7psi. it used 2 be running at 3-4 psi. wat could have caused this 2 rise like that, from memory it was running back at 3-4 yesterday, i have a full talk of fuel, and thats all i ahve really done, wat has caused the rise, and is it safe 2 drive like that
Posted on: 2006/11/1 10:21
What fuel pump are you running?
Posted on: 2006/11/1 10:38
IPRA Build
From Brisbane
Sounds like you must have always had a slight leak somewhere and now it sealed it has a 6-7psi pressure that it mite have been like the whole time with a leak. You have a regulator right?.. will just have to set it to 2 or 3psi
Posted on: 2006/11/1 10:40
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
its the stock fuel pump, and no im not running a regulator, but i will be getting 1 this weekend. my main question is, will it be safe 2 drive , as i need the ute 2 morrow
Posted on: 2006/11/1 10:44
Main problem i can see is the needle vavles overloading, float bowl over filling and causing a fire man, have you got another pump to try?
Posted on: 2006/11/1 10:52
IPRA Build
« 1 (2) 3 4 »
