A12-A15
From auckland, new Zealand
ok fellas
i have a 120y engine in my coupe, the guy who owned it before me put it in. the cert says its an A15 but i think it is only an A12 where can i look to check?
also sinse im 99% sure its a 1200cc how hard will it be tow swap it for an A15? the crossmember has already been changed not sure what to though, and custom engine mounts have been made up, so will it swap straight in or what? because i have heard somewhere that if your 1200 has had a 120Y motor put in an A15 will swap straight over.
Posted on: 2003/1/27 5:41
Re: A12-A15
The A12 has the dizzy under no. one spark plug. The others have it under no. three. How to tell exactly which one was discussed last week.
Yeah, the A13, A14, A15 and A12A use the same mounts. Only the A10 and A12 are different.
You might also take a look at the A14 swap Tech Section article.
Posted on: 2003/1/27 6:29
Re: A12-A15
the dizzy is under the number one sparky so its still a A12 but it required different engine mounts and a different Xmember.
Does that mean its an A12A?
and an A15 will bolt straight in?
Posted on: 2003/1/27 10:07
Re: A12-A15
From Melbourne, Australia
the engine number is under number 4 sparky, check this for a12, a12a or a15 at begining to see what its got
Posted on: 2003/1/27 11:30
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: A12-A15
ok i got it wrong the dizzy is under the no.3 plug but its got a12 written on it. im so confuseded please someone help.
Posted on: 2003/1/28 3:22
Re: A12-A15
From Canberra, Australia
If it has A12 written on it then it wouldn't be A15.
Unless the guy has worked it or something?
I dunno.
But you should be able to swap an A15 in there pretty easily if everything else is already done...
If it has been converted to the 120Y style A12 then everything else should just bolt up....... right?
Posted on: 2003/1/28 4:05
Re: A12-A15
Apparently Australia sold A12s after 1973, based on the A13 block? Anyways see the thread datto ute eng.
Posted on: 2003/1/28 4:59
Re: A12-A15
yeah lobster that is what i was asking, will it bolt straight up because of the current 120y engine thats in thier.
i never knew it was an A12 for sure, because the cert confused me, but i was pretty sure that it was.
so yeah, will they change straight over or what? simple yes or no.
Posted on: 2003/1/28 5:52
Re: A12-A15
From Brisbane
ddgonzal what do you mean the A12 wwas based on the A13 engine after 1973? in what way were they?
im intrested
Posted on: 2003/1/28 8:25
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Re: A12-A15
YES
edit : i tried to put that in huge font but it wouldnt work for me
Posted on: 2003/1/28 13:08
1200 Coupe Rallycar
