wiring harness part number
Quite a regular
From homeless
I figure nissan still has some in the US due to the low popularity.... and mine is ####ed. Thanks dudes
Posted on: 2006/11/22 1:03
Re: wiring harness part number
From Burbank, CA
they might...
might want to try www.oem-surplus.com ( or something like that )
the dealer is going to want more than you paid for the car most likely. Sounds like a pick a part item.
what happened to yours?
i'm wiring around the harness as it goes bad. lol.
the problem seems to be that they tended to use lots of wire and over time it's corroded and gone up in resistance, then it breaks.
Posted on: 2006/11/22 1:53
|||\ 81 KPB310 /|||
Quite a regular
From homeless
Well I stopped at the gas station and when I tryed to start it back up I had know power anywhere. Luckely I'm a wiring genius and got it fixed after buying a test light, it turned out to be a bad connection in the dash/engine harness. The wiring is tottaly hacked.....
Uhh oo gots to go back to work.
Posted on: 2006/11/22 6:12
Quite a regular
From homeless
I got these numbers from the dealer, only the dash one works on nissanparts.cc
1200 wiring harness part numbers
24013h1905
24012h1900
24012h2108
Posted on: 2006/11/22 21:40
From Burbank, CA
i just simplify as things stop working everything is aftermarket, so nothing in he dash except the speedo works anyways
Posted on: 2006/11/22 21:52
|||\ 81 KPB310 /|||
bigg, you talking about the Red 1200? It's a decent wiring harness, there are only two problems I noted:
- typical corrosion on the lamp sockets. That should be able to clean up fairly easy
- A ground problem (that we worked on, and seemed we fixed it). Symptoms: Some gauges worked, others didn't, but when you turn blinker, the dash lights came on (wrong lights), etc. It started working correctly when I pushed in the connector on the back of the dash.
Getting a new harness most likely won't solve a ground problem. It needs to be tracked down and taken care of.
Posted on: 2006/11/23 0:44
Quite a regular
From homeless
the reason I want a new harness is.....
first the white, main power wire has been melted once or twice.
2. there is but conecters everywhere.
3. If I get a new one maybe some problems will go away......
anyways I'm gunna try to order them off nissanparts.cc
Posted on: 2006/12/5 14:59
here's your chance. One is for sale
Posted on: 2006/12/7 16:45
