« 1 2 (3) 4 »
Re: Twin 40's weber help..
From Sydney
TNP I use a the same Jet calculator. The details you mention, the jets recommended for power are as follows:
Ideal carb size 40-45 DCOE
Choke size 36
Main jets 145
Emulsion tubes F11/F15
Air correctors 180
Idle jets 40f9
Pump Jets 30/35
Aux Venturis 4.0
Posted on: 2006/11/28 0:12
From Adelaide, SA
Thanks a million Benny!
Is this jet calculator a commercially available item?
Do you have a link to the company that produces it?
Or is it an in-house race secret
Posted on: 2006/11/28 0:33
From Freo
this fancy calculator, can it do Solex's and Delorto's?
and single 40's too?
Posted on: 2006/11/28 0:37
From Sydney
Yes it is copyrighted. I received a copy back in 1998. It is a great tool for baseline jetting for twin side draught carbs on a 4 cylinder engine. Basically from what I can gather it outputs data in much the same way as reading off the weber jetting tables and graphs in the Weber tuning text books.
I dont think it is published on the web anymore.
It also references jet sizings for dellortos. If someone has a table of jets for solex, then I guess it would be possible crossreference the jet size and work out the solex jet part numbers.
Like I said its a baseline. calculated by engine CC's, RPM of operation and tuned for power or flexibity.
The dyno will be the best place to fine tune.
cheers
Benny
Posted on: 2006/11/28 0:56
Good news, just found that the Jetting program Benny and I have been using is hidden away on a website, but still able to be downloaded.
Here's the link
DCOE / DHLA Jetting Program
Posted on: 2006/11/28 11:38
From Adelaide, Australia
Your a legend mate, i have to jet my 42's for my L16, also a toyota 5k motor with twin dellortos, this is a life saver!
Posted on: 2006/11/28 11:42
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Freo
Thanks for the links guy's great help to get started for the dyno.. :)
any idea how to get rid of the letters chasing the pointer..lol
Posted on: 2006/11/28 12:45
Quite a regular
From Garsfontein Pretoria South Africa
Hey Thank you verry much
Posted on: 2006/11/28 12:50
If The Road is Straight Make it Sideways
From Adelaide, SA
Awesome!
I was searching around yesterday and only turned up dead links.
Thanks a mil for the help guys!
EDIT - there's some other good stuff on his site too:
http://members.aol.com/dvandrews/
Posted on: 2006/11/28 21:53
alright .... it's an old thread but i said i'd update it with some results .....
A12 - 1204cc, all balanced.
9.8:1 static compression
gx head, all new bits
66/30 cam
electronic ignition, graphed to suit cam
4-1 hitech extractors to 2.5" collector, 2.5" mandrel bends with single 2.5" baffled muffler before the diff.
revs to 8500rpm no worries.
max power around 5500rpm without being to bogged down in low revs.
running twin 40s at the moment with 30mm chokes.
just got car on the dyno this arvo for a quick tune ....
running great thru the whole range with co2 less than 3% across the rev range, the dyno it's tuned on is probably older than some members on this site and the mech wont really give any clear figures/numbers, but i should have something by the end of the month off another dyno, dynodynamics i think ???
anyway carb settings for the motor spec above ....
40mm DCOE webers x 2
chokes : 30mm
Aux venturies : 3.5
Emulsion tubes : f11
Main jets : 125
Air correctors : 175
idle pumps : 35
pump Valve : blank
pump rod : 54mm stroke
idle jets : 45F9
Posted on: 2007/5/10 23:44
« 1 2 (3) 4 »
