Morrie engine conversion
Not too shy to talk
You'll find everything you need to know right here -
http://www.morrisdownunder.com/forum/viewtopic.php?t=1397
and yes the Japanese did take the Morris Minor engine and 'tidy it up a bit' to produce their A series.
Posted on: 2006/11/28 1:32
Re: Morrie engine conversion
From Geelong, Vic
pretty sure they tidied it up a bit to form the J series, then the a series came from a revamp of that
Posted on: 2006/11/28 1:39
No they didn't.
I'd be happy if someone can show me the similarities between the Morris A series & the Datsun A series engines. Apart from the fact that they are both four cylinder pushrod engines, the similarities end there.
Datsun took the Austin A40 engine & made the J series from it, but the Datsun A series was a clean sheet of paper design.
Posted on: 2006/11/28 2:43
Love your Datsun.
Treat it well.
From Burbank, CA
where do the similarities of the MG A series engines / trannies and ours come from?
it's pretty close...
i'm not saying anything other than they bolt together some and are interchangeable, but the datsun ones are preferred...
Posted on: 2006/11/28 3:47
|||\ 81 KPB310 /|||
Nissan was a licensee of Austin Motor Company technology and the Nissan A series was supposedly a modern replacement of the earlier iron-headed Nissan E engine and is of similar dimensions. The E series was a design inspired by Nissan's improvements to the BMC A-Series engine design in the 1950s. The J13 and J15 series were basically copied from the Austin A40, 1200cc engine but were mostly used on what they termed pickup trucks.
Posted on: 2006/11/28 20:58
