fuel pump help
From Sydney, Australia
i had a short on my fuel pump it was only 4 weeks old and the darn thing just stopped working what goes when they go and is it possible to fix? or would it be burnt out?? its a vl turbo fuell pump....unfortunate
Posted on: 2003/1/30 10:31
Re: fuel pump help
did you run a filter before the pump?
does the pump make any sound now at all?
sometimes you can switch the polarity of the wires on the pump and if you are lucky and it is only dirt it could come loose and blow back out!
Posted on: 2003/1/30 10:47
Re: fuel pump help
From Melbourne, Australia
no fuse?
Posted on: 2003/1/30 12:14
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: fuel pump help
From Forsby Finland
I had the same problem two years ago, I am using a high capacity Bosch fuelpump (240l/h) that is connetced right under the fuletank. When I installed it I didn
Posted on: 2003/1/30 12:56
I am building a mean Datsun E10 racer , a15 turbocharged engine, aiming for 280hp....
