(1) 2 3 »
L20B Head on Naps-Z Block??
Not too shy to talk
From Kauai, Hawaii, USA
I seen a post that talks about putting a L20B Head on a Naps-Z Block... Does anyone know if its possible and if u do, what do u think the performance specs on it would be???
Posted on: 2006/12/13 8:57
Re: L20B Head on Naps-Z Block??
From Geelong, Vic
yes it is apperently fairly straight forward, havnt done it myself so no personal experience, but the z series blocks are pretty much an L series so it should be easy
and the L series heads flow better than the Zs so performance would be better than a stock Z series
Posted on: 2006/12/13 9:09
From Canada
Yep, pretty straight forward as PIGDOG said. It should just bolt on.. May have to plug an oil hole (can't recall) or something like that but nothing major, bolt holes line up fine. Need to use L-series dizzy unless you can find a 4 plug NAPS engine (rare). Use either a Z20 or Z22 block. Z24 may cause clearance issues depending on application and are more likely to crack.
Stock L-series head on a Z block shouldn't have much of an increase in power but it may be noticeable, depending on which head you use. However, the potential is far greater. L-series heads (depending) can be ported much more, bigger valves can be fitted, peanut chambers, better cams, etc..
Bore and stroke a Z22 block with a decent worked L-series head and you'll have plenty of get up and go.
Posted on: 2006/12/13 14:45
From California
z22's are crack monsters
Posted on: 2006/12/13 17:44
ka24e head all the way!!!!!
twin 34mm inlets valves and one massive 40mm exhaust. Great swirl promoting awesome midrange.
Posted on: 2006/12/14 0:04
From Geelong, Vic
but how much more work is required, and what size bore do you need?
Posted on: 2006/12/14 1:14
Look at ozdat.com all info there.
Its best to use the Z block like yours but also can be done to an L series.
All homework already done and very cheap heads at wreckers.
Posted on: 2006/12/15 16:55
Not too shy to talk
so I can use a Z series block and a KA24DE head?? is that what ur saying D.... I started reading through L16/L18/L20 combos on Ozdat.com but i got tired of the arguing.... Can u give me a more direct place to start?? thanks
Posted on: 2006/12/15 18:15
From Canada
I can't help with the KA24 info. It has been done though.
As for L-series and NAPS-Z combos with regard to blocks/pistons/rods/cranks check out the link below. I can't find it right now but I'll post it up as soon as I find it.
Now cylinder heads. There's a great site with all the l-series head info on it. Casting #'s, chamber size, port sizes, etc.. If I can't find it I may be able to find the info somewhere else...
Now with all that being said. I MUST ask what your application is for. If you can tell us what you're looking for in terms of power, economy, reliability, cost, etc.. as well as what parts you have available to you then it might be easier to direct you to info on what head/block combos to use. If you have an L-series smog head then I'd reccomend ka24 head or try to source another L-series head with greater potential unless emissions are your main concern ;)
Anyone have more info Z22 blocks cracking? I've never heard of them being prone to it.Here's the link
Posted on: 2006/12/15 20:41
From California
back to your original question, yes it can be done (it has been done), but most people have gone on to other things such as the ka24e stated above
as far as specs go, it's all relative
Posted on: 2006/12/16 1:01
(1) 2 3 »
