« 1 (2) 3 4 »
Re: A14 intake pictures
Quite a regular
From Finland
- A14 block
- 76,5 mm custom made pistons for turbo use
- camsaft custom made for turbo use
- 33mm exhaust and 39mm intake valves
- A14 Oval-port "H72" head ported and polished
- standar cranksaft
- standard connecting rods
- arp head bolts, standard payen head gasget
- block amd head straightend
Posted on: 2006/12/15 14:50
A14 Turbo Power
From brisbane
what is your c/r?
Posted on: 2006/12/15 16:08
Quite a regular
From Finland
The old evo 1 motor was 9.2:1, and this new evo 2 is 8.8:1.
Yuo only need to get enough gasoline in 2 bar boost and high rpm, and also timining degrees 20-22 in full boost.
Posted on: 2006/12/15 19:32
A14 Turbo Power
Do you know if anyone has a quicker A series?
I dare say you have the record... afaik anyway
Keep up the good work
Posted on: 2006/12/15 20:56
From The garage, NZ
there are some intensly fast a series in ministock and on the track but i dout that any of them have ever tested them on the quater.
wud be good to see aye. this would definately be up there in the best.
what size turbo and what computer you using? is it just a fuel only comp?
nice setup. i drool everytime i see it
Posted on: 2006/12/15 23:57
I know hes using megasquirt, both fuel and ignition. Dunno on the turbo though, he used to run a deisel turbo, the one in the pics looks like it might be a new one?
Posted on: 2006/12/16 2:44
Quite a regular
From Finland
Almost ready.
Posted on: 2007/1/12 18:48
A14 Turbo Power
Excellent work Finn. I know the automotive laws in Europe are very hard, not easy to swap engines and stuff like that.
How is the law see installing Turbo kits in cars that did not have them??
I should assume it is oK. What a blast to drive that Datto.
Posted on: 2007/1/12 19:15
Quite a regular
From Finland
Well, here in finland you have to prove that after installing turbo there has come only 20% more power to engine, and you can put only 25% bigger engine to your car.
Posted on: 2007/1/12 20:19
A14 Turbo Power
From Las Vegas USA
That really is some very gorgeous work..........might rate as the best Datsun porn ever.
That will be a whole lot of fun to drive.
Tom
Posted on: 2007/1/12 21:10
« 1 (2) 3 4 »
