(1) 2 3 4 5 »
WHICH MOTOR? A14 vs A15
From brisbane
hi all i have hi comp venolia forged pistons,rollmaster timing set,stainless steel valves,arp bolts, lightweight flywheel,exedy clutch,twin 45mm dellortos
i have been collecting these parts for a while and was always planning on using a15 engine but now am having second thoughts
so i thought i would get a second opinion
which motor do you guys think i should use and why?
Posted on: 2006/12/20 14:07
Re: WHICH MOTOR? A14 vs A15
From Selah, Washington
The answer is simple
"There is no replacement for displacement"
Go the A15
Posted on: 2006/12/20 14:59
From Adelaide, South Australia
Yes there is it called knowing how to build an engine right.
What will be the application of the engine thats the first thing ?
Posted on: 2006/12/20 15:19
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
From Burbank, CA
yes what is it used for?
An A15 has more displacement, and also a lower max rpm. So if you don't mind going to 9000 rpm, an A14 makes a little more HP, but the A15 makes a little more torque.
Posted on: 2006/12/20 15:52
|||\ 81 KPB310 /|||
From sydney
by killer1200 on 2006/12/21 1:19:12
What if both engines were built right? doesnt the old axiom of "There is no replacement for displacement" still hold true?
Posted on: 2006/12/20 22:54
From Freo
'theres no substitute for cubic inches'
but revs are sweet..
depends what you want to do with the engine,
it will be much of a muchness..
Posted on: 2006/12/20 23:07
From brisbane
it is for road use (my ute )
Posted on: 2006/12/20 23:17
A14 = revs/topend hp, A15 = torque/burnouts .........
spend enough on either and get it built right and you wont be dissappointed
Posted on: 2006/12/20 23:33
From Adelaide, Australia
the difference is little. i use a A15 cause i weigh over 100kg so i thought the torque would help lol!
Posted on: 2006/12/20 23:59
From Springwood NSW, Formerly Tas.
like your way of putting it.. i'd go the a14 as much as i like a burnout.. having a higher "redline" is somewhat more satisfactory.. being able to say "my car revs to 9k" beats 3gear cooks. maybe...
Posted on: 2006/12/21 0:36
1978 120y Coupe.
(1) 2 3 4 5 »
