new radiator, ex speedway twin core :)
Here are some pics of my twin core exspeedway radiator for the 1200. nice thick core, approx 4 to 5 cm, sligltly larger top hose inlet and slightly angled for better air cooling through engine bay apparently.
Just got it back fom a claen and check with a few repairs.
No problems on 35deg plus days not for the
a15
Posted on: 2006/12/22 23:36
Re: new radiator, ex speedway twin core :)
From Geelong, Vic
did it come from a sunny?
so now you have racing parts, does the car go faster
Posted on: 2006/12/22 23:40
car goes good, just have to put a new tie rod on passenger side and bushes... and come see you for that diff. can we lower the rear a bit (reverse a leaf?) or stiffen it with those 120y leaves? the front handles nice with ex boof racing shocks ans springs.
The -0.8 camber and strut brace help too.
It actually is a 1960s bluebird core cut down a little and modified. Looks more like a home van one to me (but they were single cores mostly too). Has nippon on the top tank pressed into the metal.
Posted on: 2006/12/22 23:51
From Geelong, Vic
yeah that diffs still here, was tempted to cut the mounts off it to use on the skyline diff but i guess i can leave them on it
we can lower the back, dont know about lower and stiffen usually thats a job for the pros
wish i had a strut brace to test. mines still in boofs garage coz i cant be stuffed going and getting it
still gotta sort out a thermo for my car though, i think ive got one of the biggest radiators that can fit in the front of a 1200, but i still cant get threw traffic without the temp going up
Posted on: 2006/12/23 0:17
have you tried shrouding the fan and the under body radiator/sump shroud? on the coupe it used to get real hot with out them fitted. gemini radiator was a temp fix but the shroud fell off due to the weight of it and the rust in the rad support
Posted on: 2006/12/23 0:32
From Geelong, Vic
i think its more the fact that i dont have any fan the L series ont doesnt fit in as the fan would hit on the radiator support panel, one bellow the radiator
just dont have a thermo in my collection thats skinny enough to fit in the front, also cant be bothered buying a new one
the fun of L series power
Posted on: 2006/12/23 0:39
From sydney australia
you could try an n12 pulsar electric fan mounted on the front of the radiator core & with the wires connected to blow through the radiator,as these are reasonably thin,come with a shroud & move a lot of air. i've got one in the sunny with the l18 i half own, & it keeps the engine cool,but i really haven't had a chance to test it out.the radiator i had built for this car used n12 pulsar top & bottom tanks,with larger outlets & b310 sides, so it had the position to put the n12 fan switch in it, which i've wired up to run full time. i'll put it on a relay & the ignition circuit if i have a problem.
Posted on: 2006/12/23 21:30
From Melbourne, Australia
120y leafs equals a higher arse and under-steer
go some blocks
best not to play with the springs i think they are very well suited as standard
Posted on: 2006/12/23 23:42
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
just thinking of adding the small 120 y leaf and reversing one of the others to bring it down a little.
The ride height is not a real factor but the rear of the car compared to the stiff front end feels floaty and not as connected as the front end.
lookingfor a sway bar eventually but have a 120y in the front already
Posted on: 2006/12/24 4:18
well here it is compared to my stock one. no wonder the a15 hated hot days (more coming next week so lucky its in now)
idle temp droped from 180-185 to 160 to 165 farenheight.
On the freeway used to get to about 200 to 210 F when ambient temp around 30deg C but would not take it on freeway if ambient any hotter.
took on freeway same day ambient 24deg C and temp dropped from 195 with old rad to 175to 180 with new one.
Lucky have a nice 80deg thermostat in there too (same as before changing rads)
Posted on: 2006/12/28 22:24
