Browsing this Thread:
1 Anonymous Users
how to mount the throttle cable for twin DCOEs |
From Bendigo, Victoria, Australia.
here is a photo of my throttle cable hooked up to my 40DCOES, but there is nowhere for it to hook onto the rocker cover. what have people done with theres to hold the cable in place?
Posted on: 2006/12/31 2:45
"Like a Rolling Stone" Bob Dylan
New Daily: <<<<Now For Sale. 1972 B110, 13" Bathurst mags, airbrus
Re: how to mount the throttle cable for twin DCOEs |
Not too shy to talk
hey there, the easies way is to weld a bracket on the rocker cover and buy a universal accelerator cable with an adjustment screw so you can mount thru the hole in your bracket and adjust it from their.
Posted on: 2006/12/31 2:48
yeah i guess it is the best way. i just painted the bloody rocker cover though... but you gotta do what you gotta do. ill buy the bracket and new cable after the new years here.
Posted on: 2006/12/31 2:53
From Canberra
I've got a rocker cover with a bracket already welded on, but it would require you to move the half-wheel back to between the breather and where the spring is hooked. Yours for the price of postage if you want it. Its matt black
Posted on: 2006/12/31 2:58
thanks mate but i can get these parts locally. i just wanted to see how other people had done it.
Posted on: 2006/12/31 3:01
Registered Users Contentmaster Usermaster
Quote: just wanted to see how other people had done it Photos are here: Carburettor article. Click each picture to see it fullsize and read the comments.
Posted on: 2006/12/31 4:04
From Sydney , NSW
My two bobs worth ... make the bracket you desire, be it mild steel, aluminium or whatever grabs your fancy but design it to bolt to your inlet / exhaust studs. no welding to rocker cover and easily removed if need be! Enjoy the challenge ........ everyone admires a well made bracket Cheers
Posted on: 2006/12/31 6:37
From T'ville
i have done the weld it to the rocker cover thing B4 but it is neater if it is a bolt on bracket. and also the best accelerator cable i have used is a brake cable off a mountain bike because ti has a teflon liner and it never gets sticky even dry - no lubricating the cable!! cheers
Posted on: 2007/1/2 11:34
From campbelltown (sydney) australia
i think the easiest way is to mount a bracket under the rocker cover screw closest to the throttle arm pretty easy job just takes some fiddling.
Posted on: 2007/1/2 11:37
* caution, sunglasses must be worn to view my ca18det *
great ideas guys, but ive just finished making a bracket that goes onto the manifold studs. ill post up some pics when its on after the paint has dried.
Posted on: 2007/1/3 2:21
