#11 Re: RB20 pistons on A15
dattoman_1000 Posted on: 2007/1/11 9:16
I think the E15 compression height it more suited to an A14 than A15
#12 Re: RB20 pistons on A15
g1 Posted on: 2007/1/11 9:28
So i guess E15 is bad choice....how much can the A15 be overbored anyway without any overheating problem?
And...errrmmm...any other recommended pistons for a NA setup?
#13 Re: RB20 pistons on A15
dattoman_1000 Posted on: 2007/1/11 10:47
They can go to 79 on most blocks
But I'd get it exrayed first if doing that
Mine is 77 and going to 78
As for pistons..... I've used a couple of different Mazda ones and am now trying to find something better
#14 Re: RB20 pistons on A15
picko Posted on: 2007/1/11 12:09
the et turbo pistons have to be decked for the a14 block as they are proud a mm or so. have them in my turbo motor and a mate has em in his supercharge motor. you dont want turbo pstons in a na
#15 Re: RB20 pistons on A15
phat_dat1200 Posted on: 2007/1/12 12:22
is it true that you can get 77.5 in standard oversize pistons?
#16 Re: RB20 pistons on A15
datto_lowrider93 Posted on: 2007/1/13 2:18
will the pistons have to be decked with an a15?
whats wrong with turbo picstons in an na?
#17 Re: RB20 pistons on A15
Dodgeman Posted on: 2007/1/13 2:46
Dodgeman wrote
Standard oversizes are 76.5mm, 77mm, & 77.5mm
Nahhh, I just made it up.
Yes, there are three standard oversizes in half mill increments. Aftermarket pistons might be available in quarter mill [0.010"] increments, but I have not heard of stock replacements larger than 0.060" [1.5mm]
#18 Re: RB20 pistons on A15
DatsunDrifter1 Posted on: 2007/1/16 12:13
What type of compreson are you going to get? 10:1,11:1, or 12:1???
#19 Re: RB20 pistons on A15
g1 Posted on: 2007/1/17 3:32
Assume unskimmed head, & all the other settings are remained stock, BUT using the flat top pistons. What will the compression be like?
#20 Re: RB20 pistons on A15
g1 Posted on: 2007/1/22 5:43
Guys, could you please possibly help me in answering the question i asked above?... :) i need the info very much. Thank u
« 1 (2) 3 »
