« 1 (2) 3 »
Re: RB20 pistons on A15
From Perth
I think the E15 compression height it more suited to an A14 than A15
Posted on: 2007/1/11 9:16
From Malaysia
So i guess E15 is bad choice....how much can the A15 be overbored anyway without any overheating problem?
And...errrmmm...any other recommended pistons for a NA setup?
Posted on: 2007/1/11 9:28
From Perth
They can go to 79 on most blocks
But I'd get it exrayed first if doing that
Mine is 77 and going to 78
As for pistons..... I've used a couple of different Mazda ones and am now trying to find something better
Posted on: 2007/1/11 10:47
From perf
the et turbo pistons have to be decked for the a14 block as they are proud a mm or so. have them in my turbo motor and a mate has em in his supercharge motor. you dont want turbo pstons in a na
Posted on: 2007/1/11 12:09
From north brissy
is it true that you can get 77.5 in standard oversize pistons?
Posted on: 2007/1/12 12:22
will the pistons have to be decked with an a15?
whats wrong with turbo picstons in an na?
Posted on: 2007/1/13 2:18
Dodgeman wrote
Standard oversizes are 76.5mm, 77mm, & 77.5mm
Nahhh, I just made it up.
Yes, there are three standard oversizes in half mill increments. Aftermarket pistons might be available in quarter mill [0.010"] increments, but I have not heard of stock replacements larger than 0.060" [1.5mm]
Posted on: 2007/1/13 2:46
Love your Datsun.
Treat it well.
From Barranquitas, Puerto Rico
What type of compreson are you going to get? 10:1,11:1, or 12:1???
Posted on: 2007/1/16 12:13
Project R- The Real Tuner Club
From Malaysia
Assume unskimmed head, & all the other settings are remained stock, BUT using the flat top pistons. What will the compression be like?
Posted on: 2007/1/17 3:32
From Malaysia
Guys, could you please possibly help me in answering the question i asked above?... :) i need the info very much. Thank u
Posted on: 2007/1/22 5:43
« 1 (2) 3 »
