twin SU choke cable mounting
Not too shy to talk
From Vancouver, BC, Canada
Just wondering what others have done regarding the choke cable with the twin Hitachi SU set up. Currently I have a choke cable connected to just one carb. I figure it's not so bad since it warms up quickly enough that the choke doesn't need to be on for so long.
I've thought about fab'ing a bracket and connector to go betweent the two carbs, but i don't think it's the most elegant solution. I have a vague recollection of having a twin cable on my old mini I had years ago. I think it had two cables, but only one pull knob.
Posted on: 2007/1/13 2:26
Re: twin SU choke cable mounting
From Beautiful Sunny (sic) Melbourne
I made up a cable with second hand parts from a motor cycle wreckers. Lots of bikes split a single cable (usually throttle, but sometimes choke as well) into a double cable. They terminate the single cable in a little plastic tube about 5cm long which has a little "slug" that slides up and down in the tube on the end of the cable. Then on the far end of the tube there is a cap which allows two cables to enter and the inners attach to the slug. Voila! a single cable double-acting at the other end.
I'll try to take a picture and post it.
The bits cost me about A$15 at a wrecker and I got the three cables as well (one in - two out)
Posted on: 2007/1/13 5:27
Not too shy to talk
I'd be interested in that picture for sure. Thanks.
Posted on: 2007/1/13 8:40
From Christchurch NZ
Find the choke cable from a 180bsss, or a 510sss. They have a twin split cable set up.
Posted on: 2007/1/13 19:56
Forced Induction!
