« 1 2 (3)
Re: Datsun Restoration
Any pictures of your car???
Posted on: 2007/1/17 19:29
From SE Melbourne
by Datsun120AFII on 2007/1/17 22:17:01
Yep, thats right, the plastic thing on the bottom of the gear shifter was worn away, I will replace it rite away. It is the same thing for FWD cars too, I guess.
Good to know the FWD can share the same problem - you can also make those bushes out of brass if you have a lathe...
Posted on: 2007/1/17 22:38
Mildman, Datsunless
From Stockholm (Sweden)
Hej Lars
The stronger F4F60A gearbox was assembled from following chassisnumbers on:
sedan: LF10-314600
coup
Posted on: 2007/1/17 23:35
Not too shy to talk
From Norway
I will post a pic of my car as soon as my camera is back on track (it's broken=/)
From LF10-3- and on? Dang! My chassisnr is LF10-015126! That means I still have the weak box? =/
>_<
In other words - there is no point in utilizing the weaker box together with an A14 engine..?
Eh.. Maybe I'll just overhaul the entire 1.2 ltr A12 ;)
Maybe I should keep it in 100% original state? Like I do with my 76' Corolla KE30 ^^
Posted on: 2007/1/18 17:36
Not too shy to talk
From Norway
Oh. Where are my manners? Thank you so much, Fredrik!
Posted on: 2007/1/18 18:11
Not too shy to talk
From Norway
Today was a great day! I finally saw the copies of my new ignition keys arrive in my mailbox!
I brought approx. 10 litres of gasoline, four new spark plugs and a can of start-gas-spray down to my little yellow friend and jump start cable connected it to my other car, a workhorse Nissan Sunny N13.
While my brother sprayed startspray into the air intake, I turned the key..
Regardless of standing inoperable for three years, the little fellow started after three attempts - and in -23 freezing Celsius degrees!
Thats what I call reliability ;)
But.. is there any grease joint chambers behind the front wheels (maybe they are called niples? ;p)? And as for the steering box - should the oil there be changed? And what about the gearbox oil - no need for changing?
Just wonderin' :)
Posted on: 2007/1/25 1:31
NEW PICS
Not too shy to talk
From Norway
At last, after so long time.. here are some pics of my car! The nice dashboard can be shown on the picture over this text, and it is in good shape, eh?
Here is another picture of the car, from behind..
And this is of the front.. Inside, it is in very good condition... All that is left now is the body work :) I am looking forward to it ^^
Posted on: 2007/4/4 10:26
Re: Grille
Not too shy to talk
From Norway
I've heard that the grille of this car is very hard to find..? Take a look at the grille for yourself and see a piece broken off at the right side.. Seeing as this grille is absolutely in one whole piece, I guess I need a brand new grille..?
sincerely, Lars
Posted on: 2007/4/4 10:58
« 1 2 (3)
