Ca18det with stumpy box and ute??
From Adelaide
hey guys
i been reading threads.. i came across that u can put a stumpy gearbox on a ca18det with a manual trannel and u dnt have to cut the tunnel...
is this right>???
Posted on: 2007/1/20 12:13
Re: Ca18det with stumpy box and ute??
correct from what ive seen, also the stumpy from the r31 can handle alot of power
Posted on: 2007/1/20 12:17
From Adelaide
wat other gearboxs can be used without modding the tannel??
i seen stanza gearboxs can fit too.. but there to weak..???
Posted on: 2007/1/20 12:26
From Geelong, Vic
that would be an r30 stumpy not an r31
i dont think you can fit any other gearbox without modding the tunnel
even with the stumpy boxes you will need to "massage" the tunnel a fair bit
Posted on: 2007/1/20 12:36
From Adelaide
oh ok kool.. nuthing can beat a massage.. do i just rubb sum oil on it to.. ahahhaa
how much does a stumby box normally set ya back? is there many around??
cheers
Posted on: 2007/1/20 12:45
From Canada
Isn't there also a CA gazelle tranny that's close to the same length as the stumpy so the shifter comes up the stock hole but stronger? And more expensive.. and harder to find.. I seem to remember someone mentioning it. Dattodude perhaps?
Posted on: 2007/1/20 13:13
From Adelaide
another question.. wat bout an auto box?
do any autos fit up without cutting tunnel?
Posted on: 2007/1/20 13:16
From Perth WA
If you are planning on modding the ca much past upped boost and a front mount i wouldnt bother with the stumpy box, seriously its #### its just a cheap way of sorting out the gearbox, they have issues shifting at high rpm. Go for the proper ca18 silvia box its not that hard to fit mainly a little massaging with mr 4lb mallet around the front of the tunnel and you will need to cut the shifter hole about 100mm back towards the handbrake. If you can get a manual ca18 box in there there is no reason why a ca18 auto box wouldnt fit i have seen it done.
Hayden
Posted on: 2007/1/20 21:31
From SE Melbourne
It true you can use a CA18 box, I'm going to use the stumpy as the gear stick comes out the same hole as the original gearbox. As you can see from this pic - also check the wiki link.
http://wiki.datsun1200.com/index.php/CA-Series_Engine_Swaps
Posted on: 2007/1/20 22:43
Mildman, Datsunless
From Adelaide
nah my ca18det is gonna be stock..
i just want a quick sexy car... i dnt wanna go over and make it a 10sec or 11sec car..
ill be heaps happy with a 13sec car.. :)
so would the stumpy be fine with a stock ca18det??
cheers
Posted on: 2007/1/20 23:55
