« 1 (2)
Re: Ca18det with stumpy box and ute??
From Melbourne AUS
depends on the condition of the box, and how you drive it
id reccomend a larger trans tunnel, if it fits or not
will make life so much easier
Posted on: 2007/1/21 0:05
1973 B110 A12
From sydney
well when i did mine i try to find a stumpy box for under $400 i ended up getting a ca18det gearbox with a swap from my a seriers motor and then a custom tunnel for under the price of the stumpy box.
Posted on: 2007/1/21 0:08
From Adelaide, SA the drift state
with the stumpy u need a CA bell housing on it. and maddat sell a new trans tunnel which is larger.
Posted on: 2007/1/21 9:24
From SE Melbourne
by dat5_al on 2007/1/21 19:24:12
He's right there - also a bearing needs to be changed in the stumpy gearbox to make it a good fit into the CA bellhousing...so not as easy as just getting a stumpy box.
Posted on: 2007/1/21 11:47
Mildman, Datsunless
From Sydney, Australia
Andrew ca18detman put a CA18det + stumpy in a 1200 coupe with a manual tunnel. Needed to cut off the factory gearbox mounts. Which doesn't matter as they don't have to be used.
Posted on: 2007/1/21 11:55
From Melbourne AUS
must depend on the mounts a lot i think..
or maybe utes/coupe tunnels differ?
i once tried to install a ca with stumpy into a ute with maddat mounts.. and the engine could not even sit on the mounts with the trans attached while it had the standard trans tunnel... thats how far it was from fitting!
Posted on: 2007/1/21 12:06
1973 B110 A12
what about an sr20de into a 1200? what box and modifications required? i always thought cutting the firewall was a must but ive seen others fit them in quite nicely without cutting anything exept mounts
Posted on: 2007/1/21 23:26
Fits easy in 1200 with sr20de, no firewall mods.
Just need to sleeve the sr20 bellhousing for the stumpy shaft... Stewart wilkins motorsport can help you with that.
Also an auto tailshaft will mean no tailshaft mods.... Makes the conversion simple :)
Posted on: 2007/1/22 2:30
From Adelaide
i guess ill stay with the a15 for now.. and jsut buy parts each week for the set up..
cheers for ya info guys
Posted on: 2007/1/22 3:28
Quite a regular
From orange nsw
I put my ca18 turbo internals into the stumpy box when i did my conversion. when i puled my stumpy box apart to check its condition after i bought it i found that the gears were heaps smaller compared to the ca ones. i had to dissmantal the output shaft and use the stumpy one because the ca one is mutch longer. i think it should be worth the effort in the end.
can any one post some pictures up of there stumpy crossmembe, im thinking of changing mine as its a bit bodgie. thanx
Posted on: 2007/1/22 11:21
« 1 (2)
