emergency fix needed please
myradiator still has a pin hole leak.
i need to fix it asap as it only leaks undewr load or when the car is stopped, but enough to fluctuate the temp by 20deg F.
radiator shop have had it 2 times this wekk and pressure test is ok but the pin hole still weeps under the above situations.
I was going to use a 25 to 40w soldering iron but dont know if it will heat the metal enough to bond the solder to the copper tank.
Is there a putty or similar i can put on it? bear in mind i have no access to any shops or workshops till monday.
im scared to take it on the freeway in 38deg C weathewr in case it boils over. its only 13psi pressure i think from memory so would silastic or similar do the trick or just a spot weld from an arc or similar?
thanks if you can help me.
Posted on: 2007/2/2 21:07
Re: emergency fix needed please
From Invercargill, New Zealand
Put some black pepper in it - about a tablespoon. The pepper absorbs the water in the radiator and swells up. The pepper will then clog up the hole in the radiator. This repair will give you enough time to get to the garage.
Or Bars Leak has also given me excellent results when I had a fin split. I cut the fun in half and rolled up both ends and threw in some Bars and then did 80mins on the F3 in Sydney.
Posted on: 2007/2/2 21:12
From Tamworth , NSW
crack an egg into the radiator.
that ought to do it
Posted on: 2007/2/2 21:13
yeah i knbow about these bush remidies but i would rather something a little more permananet for a week or so so i dont have to eat scamblled egs out of my engine block for the next 5 years... i ve done it before, should only use the egg whites, nnot the yolk.
the hole is litterally a pin hole in the top tank... not a crak or similar, a pin hole.
Posted on: 2007/2/2 21:28
From Tamworth , NSW
what about some of that quicksteel ####e?
Posted on: 2007/2/2 21:30
From Melbourne AUS
theres gotta be something out there for u mik.. so you can cruise with us tomorrow
Posted on: 2007/2/2 21:33
1973 B110 A12
whats quick steel? is that like kneed it like ange told me about?
Posted on: 2007/2/2 21:40
From Tamworth , NSW
yeah sounds like it, any autobarn or supercheap has it
Posted on: 2007/2/2 21:42
From Melbourne AUS
sounds like this could be the stuff mik
have a read
Posted on: 2007/2/2 21:58
1973 B110 A12
this stuff works good if you sqish it iinto the hole and follow the instructions you should be right ...
used this on the old 4x4 when i cracked the neck and worked a treat for months
i'd forgotten about this stuff
Posted on: 2007/2/2 22:02
