« 1 (2) 3 4 »
Re: Building a tough A15
you are confused this time then, as you ment to say blow-through
Posted on: 2003/2/12 10:53
From Melbourne, Australia
i can never remember if its the turb that blows or sucks or the carb that blows or sucks, but thinking about that a carbs not really gonna blow is it
umm injector and twin carbs, thats getting tricky
what is standard compression for an a-15 no mods?
maybe an a-14 head is the way to go, might have to sell the GX head (ever since i ran out of money this month ive become tight and started wanting to sell stuff )
Posted on: 2003/2/12 11:00
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
whats the prob with fat gasket if made from metal??
could i use gx head and fat gasket as the gx has good flow and big valves and double valve springs
Posted on: 2003/2/12 11:02
1200 Coupe Rallycar
Quite a regular
From Pretoria - South Africa
Yep, copper gasket 2mm with GX head will do good, but if you want to start running boosts from 15-25 psi you'll have to modify the block and insert o-rings around the cylinders to keep from blowing the head gasket
Posted on: 2003/2/12 11:09
a fat gasket is more likely to blow out around the cylinders, but if its made of metal or copper the problem becomes oil and coolant sealing. Its a catch 22 situation.
Metals good and usualy seal but 3 months down the track they tend to be more prone to leak.
3 months aint long
what about three gaskets cork/metal/cork or is this getting rediculous
Posted on: 2003/2/12 11:12
1200 Coupe Rallycar
whats o-ringing worth roughly?, do you still use a gasket with this and therefore can change compression with fat gasket? will it last shlong time?
Posted on: 2003/2/12 11:13
1200 Coupe Rallycar
Quite a regular
Can do as you'll have to fix it again, just seal it with a copper sealer,
with o-ring you can use a gasket it just make it seal better under pressure
Posted on: 2003/2/12 11:14
this thread has been stolen by the king bunny (ME)
sorry, madtimmo
Posted on: 2003/2/12 11:19
1200 Coupe Rallycar
on my engine i o-ringed the block and will use a standard gasket.
and the dish in my a15 pistons has just been enlarged so it is centralised, and this is how my comp was reduced
Posted on: 2003/2/12 11:24
« 1 (2) 3 4 »
