« 1 2 (3)
Re: Datsun 1200 (4agze TURBO)Conversion.
From Tamworth, NSW
Wiring goes through just to the right (when sitting in the drivers seat) of the brake master cylinder.
Carnt really test the bottom end bearing with out pulling the engine to bits. You can test compression with a compession tester to see if your rings are ok.
Posted on: 2007/2/7 20:53
Project coupe:
Just drive it
From South Africa
take out all the spark plugs and snap a pic of them, upload it so us old farts can have a look..... Spark-plugs Speak volumes on the health of an engine.
Posted on: 2007/2/7 23:03
From Cape Town ZA
Mmmm, now I'll have to go dig out my old ones, I seem to remember that they had black carbon on them, and also some oil. Then again, the whole motor is full of oil, it was over filled with cleanish oil.
Am worried about 3 tiny pieces of aluminium I found in the sump. They weren't the usual fine fillings(which there were none of) from when you have a bearing failure, but rather looked like little pieces of casting, from when the mold doesn't seal properly, that broke of or came loose. I hope they are just that...
Also there is a lot of black carbon in the inlet ports...
Going to do a compression test, and then start it without the turbo on, to see of there are any noises inside or not. If it's buggered or loose stuff comes flying out, at least it won't break the turbo...
Posted on: 2007/2/8 0:18
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
Quite a regular
From Sydney AUSTRALIA
You guys are awsome.How do you upload pics do you copy and paste.
I had a look at all the plugs and they are dark dad 1st reaction was rich could have had slight oil but dry so it looked pretty good to him there was no markings on the plugs which is good to.
Inlet ports are dark as well bu i am not sure if it was turbo before as it came with a turbo plenim and turbo but no manifold so it could be oil from turbo(Hoping)engine is startable dad wants to rebuild now before i put in but so far its not coming back out,lolQuote:
Posted on: 2007/2/8 1:16
Quite a regular
Time for a Gear box to suit 4agze i give up trying to find a sprinter box.
Im thinking a trimatic auto or
Supra.
Does any1 no whether tunnel mods are needed to fit these boxes?
The way i see it if i pay for a bell housing i may aswell go auto(I LIKE 4drags).
And IMPORTANT
What alternators will fit on 4agze
Off what cars?
Posted on: 2007/2/8 15:09
Quite a regular
found a gearbox from a sprinter.t50
The flex plate on the engine is to big and i have to get a smaller one along with clutch and pressure plate.
My question is
Do i have to buy another starter motor to suit or will the stock one work.
Some one pleeeeeeeeeeeeeez reply asap.
Posted on: 2007/2/10 14:21
From Tamworth , NSW
i know dellow sells sprinter box's for about 650 recond if i remember right.
my toyota box required a bit of hammering around the tunnel to get it to not hit, but depending on how high the engine is mounted will depend on the amount of bashing required.
if it was already an auto tunnel it will fit no prob.
Posted on: 2007/2/10 16:14
« 1 2 (3)
