« 1 (2) 3 4 5 6 »
Re: Front brake upgrade, any suggestions?
From Brisbane
Hello boys and girls.
Does anyone know if it's possible to use the S13 upgrade and also convert to a 5stup pattern?
Posted on: 2007/2/8 13:08
if you want cost effective, stanza or 200b, should be a similar conversion in a 120y to a 1200. Very affordable and more than enough for a very good a series engine.
Posted on: 2007/2/8 13:16
From Bris-Vegas
those Kev Rowley brakes fit under 14" wheels?
Yep..... Running an almost identical setup with 14" R31 steelies.
Posted on: 2007/2/8 13:27
CA18DET '74 1200 ute project
From SE Melbourne
I hope you don't mind bundy I added the pics of your silvia swap and details into the wiki - for future generations to wonder at.
http://wiki.datsun1200.com/index.php/Strut_swaps#Silvia_Swap
Posted on: 2007/2/8 13:59
Mildman, Datsunless
From Flinders View, QLD
IS ALL GOOD DUDE, ANYTHING TO HELP THE BUDDING DATTO GENERATION
Posted on: 2007/2/8 14:28
Just trying to put the bloody puzzel back together
From Adelaide
so the bracket i marked is the one u buy for 100bucks??
i might get it made from my mate his a welder..
anyone wanna trace the bracket onto sum paper and fax it to me :)
pretty plzz
cheers
Posted on: 2007/2/8 15:21
From The garage, NZ
hey bundy. you said that 14's fit over em but what about 13's? im gna do this conversion and still wanna run my 13 inch superlites so this info would be awsome.
Looks like a good conversion.
cheers
Posted on: 2007/2/8 19:08
From Adelaide
Hey BUNDY
did u get the disk and calipers from a 1989 silvia??
is the siliva stud pattern the same width as the 120y?
cheers
Posted on: 2007/2/8 19:26
From The garage, NZ
he said on his images that it was a 1989 silvia and also the stud pattern is 4x114.3 on the non turbo versions and 5x144.3 on the turbo versions.
Posted on: 2007/2/8 19:27
From Adelaide
opps didnt see that..
do u reckon it would matter on the year? eg: would s13 or s14 fit??
as long as its the same stud pattern
do i need to do anything to the master cylinder??
im not gonna run a booster coz it only softings the push.. MEH
cheers for ya help
Posted on: 2007/2/8 20:11
« 1 (2) 3 4 5 6 »
