Rockerarm ratio??
From Forsby Finland
Does anybody now what rockerarm ratio the A14 and A15 engines has??
Posted on: 2003/2/13 9:05
I am building a mean Datsun E10 racer , a15 turbocharged engine, aiming for 280hp....
Re: Rockerarm ratio??
From Auckland, New Zealand
Not 100%, but believe they are all the same 1.25:1.
I have roller rockers in my A12A with a rocker ratio of 1.5:1 which effectively gives more lift & duration to the cam grin - probably an advantage in a turbo engine (but I'm not a mechanic).
Posted on: 2003/2/13 9:15
From Perth
So the stock ratio is 1.25 ?
I always wondered this.
I have 1.65:1 rollers. I was wondering what the difference was.
Posted on: 2003/2/13 12:08
From Little Rock, AR
The 1999 Nissan Motorsports catalog says that the stock rocker arm ratio on all A series engines is 1.44:1
I am thinking about getting some roller rockers as well, but I'm not sure which ratio to go for. I have a A15 with stock pistons/comp. ratio, unmilled head, and the cam has .414" lift will the 1.65 ratio rockers make the valves hit the pistons??? Anyone???
Posted on: 2003/2/13 22:23
From Brisbane, Australia
I thought they were 1.5, but that's probably an approximation of 1.44
Same thing applies to the L series, factory says 1.5, but in reality 1.55 is closer to the mark.
only one way to find out - trial assembly and plasticine/play-dough (or whatever). anything less than .080" clearance for the inlet or .100" exhaust will require notching
Posted on: 2003/2/14 7:02
From Kyabram vic, aust,
my 1000\1200 workshop manual tells me that the 1000 has slightly more raito that the 1200... Ill read it up tomorra
Posted on: 2003/2/18 13:23
