« 1 (2) 3 »
Re: h-190 alloy centre
From Melbourne, Australia
what about swapping diffrent brakes onto the axles, e.g. bluey disc overs, or would that be hard as the axle size for a bluey is smaller
Posted on: 2003/2/12 11:05
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
The wheel studs are in the axle, so using different brakes won't make it 4-stud. Why not just use six-hole steel wheels?
Posted on: 2003/2/13 8:05
May b for 114.3pcd 4 studs it would prob b cheaper to go for modified live axles from a L engined car if the length arent too different or you could run fwd 114.3pcd wheels on the rear if you didnt want to shorten it.
Posted on: 2003/2/13 23:23
gee, thats blindingly obvious about the studs now
it just occured to me that i could use axles from a vanette as it is h-190 aswel, but id have to have em shortened
the diff doesnt need shortening D
im not carrying two spares, i need the same stud patternl
Posted on: 2003/2/14 7:37
1200 Coupe Rallycar
From sydney australia
michael,the c20 vanette axles have smaller splines than the 520 axles.seriously,it's not that hard to get the six stud axles & drums redrilled to 4 stud.much cheaper than shortening & resplining axles.plus you'd also have 4 spare studs(i say,that was a joke,boy).
Posted on: 2003/2/14 11:07
alright fine
how much does he want for it?
would he sell just the centre?
Posted on: 2003/2/14 11:24
1200 Coupe Rallycar
cant i use my 1200 ute diff axles??? cause the end of the axle which goes in the centre is the same and theoretically the length is the same
Posted on: 2003/2/14 11:40
1200 Coupe Rallycar
Im sure the 1200 ute diff splines are different and weaker.
Also is the h190 a similar length drum to drum just b careful they may vary vehicle to vehicle Ive tried to buy and old 67 bluebird with the j15 engine and with the alloy h190 as a wreck and the width seems to be the same as my 1000 but now have gone the alfa way due to the strength and lsd.
Posted on: 2003/2/14 12:02
is 1000 same as 1200 or smaller,
my bro in law reckons theyll fit, cause we know for sure the centres are interchangable, as long as the width IS the same
Posted on: 2003/2/14 12:04
1200 Coupe Rallycar
Yeah they are but the 1000 has the alloy carrier and although not strong it makes me wonder why they put it in such an economy car. Can you get a Bluebird 410 diff?? the only prob is that some are imperial which I wouldnt know how that would affect things if the pattern is the same.
Posted on: 2003/2/14 12:11
« 1 (2) 3 »
