A14
From Invercargill, New Zealand
I commute 850 k's a week using a standard A14. Under load or acceleration the motor is running perfectly and still revs to 7000 if I'm feeling anti-social. At constant speeds e.g 60 kph or 110 kph I have started getting an intermittent missing fluttery sort of hesitation - it's just enough to notice. My fuel economy has dropped as well. Points, plugs, filter, timing, leads and carb are fine. Anyone experienced this or have any ideas?
Thanks all.
Posted on: 2003/2/15 14:33
Re: A14
I had similar problem as this once. It was a jet in the carby I think. Anyways, after rinsing out the carburetor and spraying cleaner through all the passageways it worked fine once again.
Posted on: 2003/2/15 19:21
Re: A14
From sydney australia
yer,i also had a similar problem,it was dirt in the idle curcuit.unfortuneately,to clear it out meant taking the carby off,& back flushing with carby cleaner from the bottom.this would usually last a couple of months.
Posted on: 2003/2/16 6:41
