a15 head on a12
From Springwood NSW, Formerly Tas.
whats the go,
all i need to know is, whats the compression like, and do all the oil galleries and water ports line up,
and dont say use the search, cause i did, all i need is a simple answer, and i have an a15 head gasket too, ps i dont have the head yet, as its all based on this information
Posted on: 2007/2/26 8:16
1978 120y Coupe.
Re: a15 head on a12
From UK
I found this link when I was doing my own research for my engine. Its from the links section of this website
Datsun 1200 Modifications
Posted on: 2007/2/26 9:47
Re: a15 head on a12
Not too shy to talk
From Broome, Western Australia
I have an a15 head on my a12 racing engine and have never had any problems . all the oil ports line up and i use an a15 head gasket. I am not sure on the compressions lol but arnt they usally written on then intructions that come with the gasket? You can also put a15 manifolds on to the a12 ports wich makes the engine breath easyer especilly with inlet manifold. You can compare the size of the a12 annd a15 gaskets . the size is quite great and you can imagine how much difference they make.- Lisa
Posted on: 2007/4/26 9:51
Re: a15 head on a12
Dato9 wrote:
You can also put a15 manifolds on to the a12 ports wich makes the engine breath easyer especilly with inlet manifold. Lisa
No you can't put A15 manifolds on A12's, at least, not the inlet manifolds as the flange stud pattern is different & the larger oval port shape of the manifold would offer no advantage with the smaller round inlet ports, even if you could fit it.
An A15 manifold will bolt up to a Datsun 1200 or A12 GX head, but it would not be an advantage over the GX induction.
Posted on: 2007/4/26 10:22
Love your Datsun.
Treat it well.
