anyone actually tryed this??
From The garage, NZ
Hey, i heard somewhere that you can use s13 camber plates in our 1200's.
I measured the bolt spacing and they should fit.
just wondering if anyone actually fitted them?
Also what is everyone running in terms of camber plates?
chris
Posted on: 2007/2/26 0:25
Re: anyone actually tryed this??
From Geelong, Vic
most people that i know run either s13 or r31 camber plates, but i think that you need to have a bit of the camber plate machined out so that you can acheive decent camber
as you are sorta putting them in backwards
Posted on: 2007/2/26 6:19
or 510 (1600) plates .... and yes you will get alot more camber if you have some machined out as you are putting them in backwards
Posted on: 2007/2/26 7:10
i didnt machine mine out and am getting 0.9 deg neg camber, but that better than 1 deg pos camber from before!
wish i did get them machined but cant be bothered taking them out again.
Posted on: 2007/2/26 17:22
From Geelong, Vic
or you could not run camber plates and have more than a degree of neg camber like me
Posted on: 2007/2/27 0:17
From Gold Coast, Australia
umm... i dont understand this?? i have S14 ones from my front cut, how can i put them to use?
Posted on: 2007/2/27 2:47
From Melbourne, Australia
by machine out do you mean elongate the adjusment hole or more serious than that?
Posted on: 2007/2/27 2:58
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Geelong, Vic
machining sounds more profetional
but yeah, elogating the adjustment area
to put the s14 ones to use, put them in the datto and see what doesnt work
Posted on: 2007/2/27 3:04
