It took me all day just to finish the inner quarter off, prep and paint it and tack in the new rear quarter! It did warp a little bit near the wheel arch and there is a low spot which will need nocking out and then filling etc.
Here is the result of a days work, finally tacked into position
Another view of it
This is the inner rear quarter repair, the whole lower section was cut out and i bent up and welded in new steel. Note that its welded properally just slapped silicone over the top so it looks neeter and extra protection! Ive found that you can use the tailgate of a trailer to bend small 1.6mm steel by pushing the steel through the gap and bending up
Ive also left a decent gap between inner and outer quarters so #### dosnt collect again and rust out
Another angle of the inner quarter, needs finishing with protector/paint
Soon i will be up to the time consuming task of using filler to make everything run together smoothly
