Is there throttle body fuel injection for A series?
From Mesa, Arizona, USA
Does anyone know if throttle body fuel injection is made for the A12 like Holley makes for V8's? I would like to install fuel injection but want to keep it fairly simple. If not, what car is the easiest to use the fuel injection from?
If you want to see the start of my project, 73 coupe, check out my web site. Not much to see now but it's started.
www.cyberdaddy.net
Thanks guys
Posted on: 2007/2/28 23:19
turboron@hotmail.com
If it ain't broke, fix it until it is!!!
Re: Is there throttle body fuel injection for A series?
From Darwin NT
i think some a12s or a14 come out with fuel injection in japan or somewhere in asia anyone no where?
Posted on: 2007/2/28 23:34
current project 4x4 patrol...
i was thinking of the same thing for my sedan, Try turbo city www.turbocity.com they have throttle body setups, but i'm not sure if their kits come with a user programable ecu. i think they use gm sensors.
Posted on: 2007/3/1 0:09
From south coast, nsw
try efihardware.com they should have what u are lookin for????
Posted on: 2007/3/1 0:27
Not too shy to talk
From Canberra
I have the genuine A series article (with adapter running a Commode tb), however GSX1100 bodies (or similar) on a weber man will work, marginally(!!!!!) cheaper than EFI hardware.
Cheers
Kevin
Posted on: 2007/3/1 0:50
The Little Engine That Does.
No such thing. Nissan made a tuned-port injection for the A-series (A14 & A15). They never made any fuel injection for A12 unless you count the "works" engines which again used a tuned port manifold.
Throttle-body fuel injection is in a form similar to a carburetor, where it bolts to a carb-style intake manifold. You should be able to adapt other units, or even use the Holley article.
Posted on: 2007/3/1 0:59
Not too shy to talk
From Canberra
Oh, ok then, twisted tongue- I have a commode tb on an A series PFI manifold, If that helps. Try an EA Falcon TB on as big an inlet man as possible. I think they have, roughly, weber spacing.
Cheers
Kevin
Posted on: 2007/3/1 2:06
From Perth WA
I was searching through old threads looking for god knows what and i found a rather long thread on adapting Ford Falcon 4.0L (EA-EB)6cyl motor Centre Point Injection. Apparently its the same as a Weber bolt pattern. I didnt read into it all but people were trying to get away with the original comp too!
Donno what car that would corrospond to in the US market.
Posted on: 2007/3/1 5:43
Chris...
From Wagga Wagga
u can do it the way I do it
Posted on: 2007/3/1 19:07
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
From Canberra
by beattie on 2007/3/1 15:43:26
yeah my mate has one of these off an old Alfa or fiat or something, made by weber so it will bolt to a weber downdraught adapter, its just a butterfly with a big injector over the top.
Posted on: 2007/3/1 20:33
