« 1 2 3 4 (5) 6 »
Re: Megs datsun 1200 ute 4agTe ground up build up
From Wagga Wagga
rocket switch is good, they look mad 2
Posted on: 2007/3/6 15:41
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
Quite a regular
From Sydney AUSTRALIA
then id have to have 2 switches cause need parkers.
Also
Is the the radio on top or demister.
Are the hi beam on the blinker
And do they have hazard lights.
bro made glove box todat and where the mph guage ends its broken so puting plate with the switches i need
If any 1 has picture of factory 1200 dash complete
And 1 of the fire wall will be handy.
Posted on: 2007/3/6 22:31
From Tamworth , NSW
1) radio on top
2)yes hi beam is on blinker stalk
3)hazard lights are on top of steering column
Posted on: 2007/3/6 22:42
From Christchurch, New Zealand
I just dont want to spend that much with dellow when every1 i have spoken to has said there poor quality.
Who said that? I have brought a dellow kit before and found it very very good with a supra box behind my old 350chev v8 VK commodore, as many of you guys have said, indestructable! theres some guys out there who run mega HP v8's with dellow/supra combinations and have no problems. problem is price, i agree on it for one, but its defiantly worth it in the end, cheaper in the long run rather than spending thousands on replacement boxs.
Posted on: 2007/3/6 23:25
From Tamworth , NSW
especially for us guys who run an a series.
strength is no prob, 5 gears is heaven, and datto five speeds are just waaaay to dear
edit: ive been running the dellow kit in my ute for 2 years now, and by jingo has it had a hard life, still as good as the day i put it in.
Posted on: 2007/3/6 23:32
some datsuns, pre 76 i think dont have hazzard lights... my sedan , no, my ute no, my coupe no, 3 others ive wreked, no... but all pre 76.
all you need is speedo, instrument panel with oi warning, fuel, etc, wiper switch head light switch and your demister heater controls... the rest (cig lighter, choke and tacho arnet needed, tacho you can use aftermarket anyway).
If you are using 4agze block and depending o n what computer you are using to run it all, might be easier to graft the instrument panel from a sprinter in there for the gauges and depending on what gearbox your running, depends what speedo you will want to use accurately.
Why make it harder than it has to be, easier to find the corolla stuf anyway than 1200 stuff
Posted on: 2007/3/6 23:42
Quite a regular
found a complete engine and box for cheeper then the housing kit...
mite just buy that and when it blows sell the spare engine and buy the dellow setup.
There popular with the v8s i no.
Not so popular with peoiple on toymod.
My friend said theres a nz brand called nite something but dont want to think what postage will cost.
Also seen a complete sprinter for $350.
if i could run the dellow housing and buy everything else somewhere else for cheeper i would go that option 4 sure.
Posted on: 2007/3/6 23:47
Quite a regular
mine is 71 model
so i need
wiper switch head light switch and demister heater controls and box...........pm me any1
i have the bottom piece of shroud.
Need the top...........pm me any1
also how does the key thingy go
does it bolt in shroud or i need bracket
and can i use a stock 1200 cable and a stock sprinter cable and make 1 some how that will work...
I love the old dash
I want to keep it.
CLASSIC
Posted on: 2007/3/6 23:52
cant say ive ever heard of a company that makes them here in NZ, be interesting to find out. If they are any good, im sure shipping wouldnt cost too much.
$350 for a sprinter, thats pretty good, pitty that they arent that cheap here.
Posted on: 2007/3/6 23:53
From Canberra
I think I've hot headlight and wiper switches, from a 120Y but I'm pretty sure they're the same.
key thingy (ignition barrel?) should bolt around the steering column, I have one from a 120Y with 2 original keys if you want it.
talking about speedo cable? the datsun one will screw straight into the T50.
Posted on: 2007/3/7 11:46
« 1 2 3 4 (5) 6 »
