Re: What are the benefits of a larger brake master cylinder?
From Bris-Vegas
You'll get a lesser mechanical advantage by using larger master cylinder.... Pressure=Force/Area.
ie/ More work req'd by you.
As you've increased the diameter of your brake pistons by a fair bit by going to the Silvia / R31 brakes, you're already getting a heap more mechanical advantage than stock.
with that in mind, I reckon a slight increase in your M/C size wouldn't hurt.
But - As any tradesman will tell you.... If it aint broke, don't fix it
Posted on: 2007/3/7 20:41
CA18DET '74 1200 ute project
From Brisbane
i'm running a 13/16 sunny, with twin sumi's and R31 rear, very hard pedal and only about 10mm
pedal travel
Posted on: 2007/3/7 21:30
From brisbane
Thankyou for all the responses.
There has always been a fair bit of pedal travel which has never worried me as the car pulls up very well.
Would I see a reduction in braking distance by fitting a 240Z 13/16 master cylinder?
Matty
Posted on: 2007/3/8 1:24
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Geelong, Vic
240z master is 7/8ths, yes you would see a reduction, you will have about an inch of travel
id try maybe a 120y 3/4 or sunny 13/16ths, even the 13/16ths might be a bit much
but they are only about $80 brand new so its not exactly a huge loss
Posted on: 2007/3/8 1:34
From California
matty wrote:
Matbighat - with the increase in caliper and piston size of my modified system will a bigger master cylinder allow increased braking force to be applied at the expense of extra effort on my behalf? Or, as Dodgeman has mentioned, will it just mean that the pedal doesn't travel as far?
yes, but you'll need to experiment. don't go too much larger than what you're running now unless the pedal is still too soft for your liking
Posted on: 2007/3/8 7:05
From brisbane
Thanks Pigdog and Matbighat.
My current 120Y one is 11/16". If I go to a 13/16" that will be an increase of 16%. Does anyone see an issue with an increase of this size straight up?
Thanks Matty
Posted on: 2007/3/8 9:01
From brisbane
Pigdog - where have you bought master cylinders for $80 from?
Thanks Matty
Posted on: 2007/3/8 9:13
From Burbank, CA
using the large sunny MC with wilwoods ;) very nice pedal feel!
Posted on: 2007/3/8 9:25
|||\ 81 KPB310 /|||
From Geelong, Vic
i get my mastercylinders from my local brake place, if you cant find any that cheap let us know and i can get one for you, only be like $10 to post
Posted on: 2007/3/8 15:27
From brisbane
Thanks Pigdog.
Posted on: 2007/3/8 20:13
« 1 (2)
